Clutch will not engage - JeepForum.com
post #1 of 4 Old 11-26-2008, 01:52 PM Thread Starter
lonestar_yj
I just recently bought a 93 jeep wrangler with a blown motor 4.0 and a 95 jeep chreokee with a bad transmisson for $1500. I picked up a running 4.0 out of a 95 jeep cherokee for $150. Bought a new clutch kit and installed, went to bolt the transmission to the motor and found out the shaft on the trasmisson would bottom out inside the crank with a 1/4 inch left between the motor and trans. We ended up cutting a 1/4 off the trans. shaft and bolted it up and dropped in. We bleed the clutch, but it will not go into gear. When you step on the pedal it is like you are pushing the brake, hard. Does anyone have any ideas
Thanks
lonestar_yj is offline
post #2 of 4 Old 11-26-2008, 02:07 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
If the pedal is that hard, I would say the pressure plate is not allowing the slave cylinder to depress the fingers on the pressure plate. Something is misaligned, or binding up.
As to what it could be, I have no idea. But I'll bet that by the time you figure it out & fix it, you'll be able to whip a tranny in & out faster than most folks. It looks like you have some more intimate time with the underside of your Jeep this weekend....
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 4 Old 11-26-2008, 02:43 PM Thread Starter
lonestar_yj
as of last night i have put the transmission back in it for the 3rd time in 2weeks. the first time after we bleed the clutch, it blew a o-ring out of the throw-out bearing, pulled it back off and replaced, blew the o-ring out. Warrantee replaced the bearing put it back in.
post #4 of 4 Old 11-26-2008, 03:05 PM Thread Starter
lonestar_yj
i also have a set of 35X12.5 tsl thornbird super swampers, and a 1995 jeep cherokee 4.0 I6 4X4, needs a transmission for sale.
Clutch Pedal soft, no resistance, does not engage clutch. Shivam YJ Wrangler Technical Forum 25 02-20-2017 03:10 PM
A/C clutch won't engage Gomofast TJ Wrangler Technical Forum 31 01-13-2010 08:55 AM
clutch deosnt seem to engage. jdayfdlt334 TJ Wrangler Technical Forum 1 12-09-2008 07:05 PM
Cannot engage clutch... jarods7920 TJ Wrangler Technical Forum 2 11-22-2008 06:32 PM
Where should the clutch engage? vmann7 YJ Wrangler Technical Forum 2 08-10-2008 03:49 PM
