clutch/trans vibration - JeepForum.com
post #1 of 3 Old 08-31-2011, 07:32 PM Thread Starter
ikircher
hey guys i tried to search but couldn't quite find a specific answer...i have a 95 yj with 2.5 liter and 5 speed. when i take my foot off the clutch there is a vibration.. its not too bad yet but its noticeable. when i push on the clutch the vibration goes away... also for what its worth when i go in reverse the jeep wants to jump around almost unless i give it a lot of gas. there is also small vibrations and bucking when i take off in first. after reading it seems like maybe a bad pilot bearing... could anything else cause this issue? thanks in advance everyone!
ikircher is offline
post #2 of 3 Old 08-31-2011, 07:33 PM
Dragon5
Mine does the same thing. Some days worse than others. I think they call it clutch chatter.
Dragon5 is offline
post #3 of 3 Old 08-31-2011, 10:33 PM
kahanabob
Yep...chatter...mostlikley time for new clutch and flywheel resurfacing.............however need to check your motor mounts if they are shot then that could be the issue, the enging is jumping up and down when you let out the clutch..........
kahanabob is offline
Auto trans R&R'd... now a vibration.. thoughts? tw_jeep TJ Wrangler Technical Forum 5 01-24-2009 10:06 AM
Trans Shifter Vibration but Everything Else Smooth Jim93YJ YJ Wrangler Technical Forum 2 10-06-2008 12:58 PM
weird clutch vibration mean90yj YJ Wrangler Technical Forum 0 07-19-2007 07:51 PM
Vibration..Are my Trans mounts bad? NCJeep YJ Wrangler Technical Forum 5 03-30-2003 05:41 PM
trans shake/ vibration during reverse hinrg02 YJ Wrangler Technical Forum 6 09-10-2002 03:53 PM
