Clutch or Tranny?? - JeepForum.com
post #1 of 5 Old 02-06-2002, 04:00 PM Thread Starter
Nine5YJ
Clutch or Tranny??
Hey
Driving on the highway i do 75 and my RPMs are usually at 2800-2900. Lately, they have been up by 3100 to keep the same speed. Could my higher Rpms mean my clutch is starting to slip, or could my tranny be needing a flush? Any ideas? thanks!
95 YJ, 31 x 12.5 ProComp ATs / AR767 wheels, stock 4.10s, 2 1/2" Rough Country Suspension Lift, and huge rusty basketball sized drain holes.
Nine5YJ is offline
post #2 of 5 Old 02-06-2002, 04:19 PM
West
Transmission flushing is for automatics transmissions. With a manual your gears will not slip "a little", they are either engaged, disengaged, or making noise thats lets you know you definately have a problem
West is offline
post #3 of 5 Old 02-06-2002, 07:29 PM
osburn
osburn's Avatar
Is it periodically, like under heavy load, winding up the RPMs? Or does it just always stay at 3100? This is a manual right?
Matt Osburn
Score 1032
osburn is offline
post #4 of 5 Old 02-09-2002, 03:53 PM
NOVA Jeeper56
Hey,
You might want to invest in a new clutch, you are slipping
'94yj, rancho lift kit, 31x10.50 BFG mud's,intake,exhaust,wheels, warn 6000lb winch,lights,
bumpers/brush guard
(used to be known as BiggMike56)
NOVA Jeeper56 is offline
post #5 of 5 Old 02-10-2002, 11:51 AM Thread Starter
Nine5YJ
Hey
I took it to my mechanic and ended up getting a new mufler, tailpipe, radiator, thermostat and a full tune. when i first bought it, i had to replace the cat. the stone broke apart, and it was clogging up my muffler. there was a bunch of crud all caked inside, and basically no air was getting through so the pressure was building up when i'd accelerate. clutch and tranny are fine. i was most surprised at my radiator. its only 6 years old with 38K on it. Anyone else had to replace a radiator this soon?
Nine5YJ is offline
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
clutch or the whole tranny? GreenBeast TJ Wrangler Technical Forum 4 03-26-2008 07:28 PM
Clutch/Tranny YJ Newby YJ Wrangler Technical Forum 7 06-21-2006 09:37 AM
Tranny/clutch?? Jeep Yj Fred YJ Wrangler Technical Forum 1 10-15-2005 06:05 PM
clutch or tranny? joop YJ Wrangler Technical Forum 17 12-24-2003 09:09 AM
