Clutch Slipping - JeepForum.com
post #1 of 5 Old 07-11-2013, 09:14 PM Thread Starter
MBRUBICON
Clutch Slipping
My clutch would slip in my 1995 Wrangler 2.5L on 36s and 4.88s when I would be on big rocks. I removed my clutch everything looks good no hot spots and the clutch has a good amount of material. Any ideas from what I read the performance clutches are a waste.
06' Rubicon 5.3/4 lift, warn 9000XDi, TKH fab Bumpers, 4.88s
95 Wrangler 2.5L 36's 4.88s
91 Wrangler
78 Dj5
75 Cj5
MBRUBICON is offline
post #2 of 5 Old 07-12-2013, 09:38 AM
jokerchief462
Resurface the flywheel and not smooth like a brake rotor it should be textured. I am not a machinist but there is a difference. If the pressure plate is good I would suspect maybe the little clutch is just not up to the task.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 5 Old 07-12-2013, 01:52 PM Thread Starter
MBRUBICON
I am afraid that its not up for task but I did order a new clutch and flywheel to day.
91 Wrangler
78 Dj5
75 Cj5
post #4 of 5 Old 07-12-2013, 02:12 PM
SeanB95YJ
^^^ this
sort of picture the way a fresh hone looks on a cylinder wall... it's not a polished smooth, but a cross-hatch pattern
brings back funny memories.... my grandfather (RIP) was a mechanic all his life - top notch, could set timing to within half-degree just by sound and feel. could usually diagnose a problem before even opening the hood.
anyway, when he would do a clutch replacement, while the trans was out, he would start the engine, and get under the car with just a piece of 150 grit emery paper and a lit lucky strike hanging from his teeth and resurface the flywheel by hand with the engine running, using the engine as sort of a lathe... the man was nuts but could run circles around most other mechanics who had twice the diagnostic equipment & machinery.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #5 of 5 Old 07-12-2013, 05:12 PM
rambo3489
Performance clutches are a waste unless your putting BIG HP though it. Everyone else has stated the main points.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
