Clutch Slave Cylinder - Page 2 - JeepForum.com
post #16 of 18 Old 04-30-2013, 06:45 PM
idaholtby
Given your username, I derive that you have a '91. If so, and if stock, your '91 has an internal slave which is a totally different animal from that discussed in this old thread. If you stick with the stock internal slave, then you will notice that a bleed line protrudes from the Bell housing, and this is where the answer to your question lies. The confusion may be that the external slave model years (94-95) are typically sold as a complete assembly that is pre-bled and filled. The internal slave set up such as yours requires to be bled manually via the fitting that protrudes from the bell housing. You may also consider upgrading your rig with the external slave set up.
idaholtby is offline
post #17 of 18 Old 04-30-2013, 06:45 PM
jkilmer83
1983 CJ7
You should be able to bleed it just like a brake setup. Gravity, vac-pump, pump it hold and crack the bleeder, act.
1987 yj w/(new)258 .060 over comp cam mc 2150 carb
1989 yj sold
1983 cj7 w/258 t5 dana 300 45k original
mc2100 carb
You just can't fix stupid!!!
jkilmer83 is offline
post #18 of 18 Old 04-30-2013, 10:24 PM
Opihi59
from here it gets rough
Opihi59's Avatar
No, there is a bleeder that pokes out the front of the bellhousing, you bleed it from there. Look at your present system, you'll see a hard line going into the tranny, and another one that pokes out the front with the bleeder on the end of it--that's where you bleed it.
Take a moment to fill out your profile so we know more about what trans you have, AX5 or AX15.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
clutch slave cylinder wirefire TJ Wrangler Technical Forum 3 10-29-2010 06:38 AM
Clutch slave cylinder Sungard YJ Wrangler Technical Forum 10 04-26-2008 01:16 PM
Clutch Slave Cylinder Eric_D YJ Wrangler Technical Forum 5 05-11-2006 05:34 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
clutch slave cylinder BPAGS11 YJ Wrangler Technical Forum 2 01-27-2003 05:51 PM
