Clutch Slave Cylinder - JeepForum.com
post #1 of 18 Old 01-13-2008, 12:11 AM Thread Starter
AZ95YJ
Well it's been a while since I have posted here, but I'm running into a slight issue that I need some help with.
I am replacing my clutch slave cylinder. Luckily mine sits on the outside of my bell housing . I purchase my new one from Autozone and lo and behold I find that the bleeder valve hole is completely closed off. My question is that is it supposed to be closed off, or is there a really small plug down there that I need to remove? If it's supposed to stay that way, then how in the heck am I supposed to bleed my clutch?
Oh (and I'm sure that you guys will love this), the guy at Autozone told me that it was a "self-bleeding" slave cylinder.
Thanks for your input.
AZ95YJ is offline
post #2 of 18 Old 01-13-2008, 01:31 AM
Kalesinajeep
ya
people are stupid
1 the clutch cylinder line and slave are a sealed unit. the jack off sold you a part that dosnt exist... go figure
the there should be a screw in your old one to bleed. i had the same problem about 6 weeks ago
Kale Saether
1995 YJ Wrangler,1999 TJ 2.5L Motor
Rubicon Express Exteme Duty Lift,
Black Cragars,32" BFG MTs,
White Jeep Club Member #116
Kalesinajeep is offline
post #3 of 18 Old 01-13-2008, 01:52 AM
mud-slinger
Pull the bleeder off of the old slave cyl....self bleeding? Ya sure.....
1991 White Wrangler 2.5l 4" lift
33-12.5 15 Bf Goodrich Mud-Kings on 15x10 Ultra Rims
Herculined tub
My "Money Pit"
White Jeep Club Member #442
mud-slinger is offline
post #4 of 18 Old 01-13-2008, 06:38 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
They are "Self Bleeding" now. He sold you the right part.
Put it in per the instructions and you bleed it by pumpuing the snot out of the clutch. The bubbles rise up the line.
- Ernie
Richmond88yj is offline
post #5 of 18 Old 01-13-2008, 08:53 AM Thread Starter
AZ95YJ
Well I did pump the snot out of the clutch, and bubbles did rise. However my clutch is still not right. Normally it engages when I first step on the peddle (meaning that I don't have to mash it down all the way to engage) and then disengages just a little before I take my foot off of the peddle. Now it doesn't engage until my foot is about at the floor, and disengages just barely after my foot starts leaving the floor (plus it still feels squishy).
Unfortunately I don't think the bleeder is something that can be removed by itself, because it is part of the slave cylinder unit. It's merely a hole at the top that a screw sits over.
This part has the same screw point, it's just that the hole that should be at the bottom is not there.
Oh, and the line can be removed from the slave cylinder. It's merely just a pin that holds it to the unit.
I guess I'll have to take it out, put in my old one (it still works but feels weak) and mess with the new one. This way I will at least be able to get to work.
95 Jeep Wrangler Sport (mostly stock right now)
Airaid intake system
Gibson Cat Back
AZ95YJ is offline
post #6 of 18 Old 05-27-2010, 07:13 PM
camevans
hey im new at this. i had to replace the clutch hose that goes from my master cylinder to the slave cylinder. unfortunately the fitting that the hose goes onto the slave cylinder broke. and i have to buy a new slave cylinder (180 bucks) just to use that fitting off of it. is there any other way around this?
camevans is offline
post #7 of 18 Old 09-26-2011, 07:03 AM
95Turtle
To the OP, did you ever get this problem resolved? I put the same slave in about 2 years ago, and I still have problems. The pedal is still squishly like you said and the clutch engages right off the floor. I only put a few hundred miles on the Jeep in a year, so I haven't worried about it much, but it is annoying. I'm sure the problem is that air is still in the system, but I have had no luck trying to bleed it by opening the set screw on top of the slave and pumping the clutch. Has anyone had success with another method?
Thanks
95Turtle is offline
post #8 of 18 Old 09-26-2011, 08:41 AM
moonshinefuel
The clutch engaging right off the floor can also be a weak or collapsing pressure plate. Of course ruling out the hydraulics first takes precedence.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #9 of 18 Old 09-26-2011, 08:51 AM
95Turtle
Moonshinefuel, had the pressure plate problem in an F150 once. This seems a little different, like a clutch feels before you get it completely bled. And I replaced the pressure plate, clutch disc, throwout bearing, etc at the same time as the slave. I just really don't like this "self-bleeding" slave, it seems impossible to get air out of it once it is installed. Has anyone heard of a slave with a traditional bleeder valve for the 94-95 models?
95Turtle is offline
post #10 of 18 Old 09-29-2011, 09:32 PM
mudsling
I replaced my slave cylinder with a new one, only to find out that the bleeder "did not bleed". I exchanged it 3 times and they were all the same, so I took a small drill bit and put a amall hole in the bleeder hole (bleeder hole is blocked by plastic). Problem solved.
mudsling is offline
post #11 of 18 Old 11-24-2012, 09:05 AM
delb
clutch hydraulic system problems
We have replaced the hydraulic master cylinder along with the master cylinder line, thought the problem was solved. We bleed the line with new fluid and it worked fine for about two to three weeks and now we are using fluid causing lost pressure in the clutch. Where is the fluid going? There is no leak we can find, we keep refilling the fluid but it only lasts about a day. please help me !
Me and my dad a stuck!
Thanks.
delb is offline
post #12 of 18 Old 11-24-2012, 10:41 AM
pasinbuy
Thanks.
Your profile is not filled out and my mind reading abilities are not the best.
Fill out your profile!
pasinbuy is offline
post #13 of 18 Old 11-24-2012, 10:53 AM
stenyeart
X2
My guess is that you have an internal clutch slave cylinder and that is why only the master cylinder and line were replaced. The new master cylinders works a lot better then the one it replaced. It builds more pressure and your worn out slave cylinder could not hold up to the pressure. It is now leaking inside the bell housing.
This would be my guess without knowing more about your jeep.
Apparently this thread comes back to life once a year.
stenyeart is offline
post #14 of 18 Old 11-24-2012, 11:28 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Kinda like my wife (The Dragon Lady) during the Holiday shopping season...
It's not a bad thread though, it's been resurrected a few times and it does show our new member discovered the search function.
So--look for where you're losing fluid, it does not evaporate, and it is not consumed in the process of functioning. A master cylinder will leak inside the cabin, where the rod comes thru the firewall and connects to the clutch pedal. Fluid will dribble down the firewall and if you have carpet (ew!) it will hide behind there.
If you have an internal clutch slave cylinder, like in 93 or older YJ series, it will be inside your bellhousing, and fluid will dribble out the jct of the bell to engine and you'll confuse it with an oil leak. Engine oil feels like engine oil, but brake fluid has a "warming" sorta feel to it when you rub it between your fingers. So lay a clean sheet of cardboard under the Jeep, watch where the drips are falling. The best guess is that your internal slave is dead/dying, and it's hemorrhaging is getting mixed in with all the other gunk like engine oil leaks, RMS leak, etc and you can't tell the difference.
Welcome to the forum, thanks for finding the search function, but yes, do fill in your profile as I'm sure you'll have more than one post in your Jeep career.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #15 of 18 Old 04-30-2013, 05:45 PM
91_andYJ
Opihi59 - i'm dropping my tranny n transfer case to replace to the slave cylinder in the bellhousing but how do i bleed it after i put the new one in? from the resevoir like the power steering?
91_andYJ is offline
clutch slave cylinder wirefire TJ Wrangler Technical Forum 3 10-29-2010 06:38 AM
Clutch slave cylinder Sungard YJ Wrangler Technical Forum 10 04-26-2008 01:16 PM
Clutch Slave Cylinder Eric_D YJ Wrangler Technical Forum 5 05-11-2006 05:34 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
clutch slave cylinder BPAGS11 YJ Wrangler Technical Forum 2 01-27-2003 05:51 PM
