clutch screamin - JeepForum.com
post #1 of 8 Old 09-17-2011, 09:35 AM Thread Starter
newyj
clutch screamin
hey guys why is my clutch screamin when I push in the peddle master appears ok?
wave back dammit, don't leave me hangin!
yes, I wave at night too
newyj is offline
post #2 of 8 Old 09-17-2011, 10:01 AM
moonshinefuel
Throwout bearings will make a lot of noise if they are bad. Basically a spun bearing. You will notice it most when you feather the clutch and as you are starting to press the clutch pedal down.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 8 Old 09-17-2011, 10:07 AM Thread Starter
newyj
was makin light noise when not pressed, now it screams the range of engagment
newyj is offline
post #4 of 8 Old 09-17-2011, 10:36 AM
moonshinefuel
I had a throwout bearing make light noise as you describe when not pressed. The bearing just slightly is up against the pressure plate tabs enough to move the bearing race.
It seems like a bad throwout bearing from your description to me.
Bow Hunting
post #5 of 8 Old 09-17-2011, 12:53 PM Thread Starter
newyj
thanks, is it hard to change?
newyj is offline
post #6 of 8 Old 09-17-2011, 01:32 PM
moonshinefuel
It's your whole clutch you will be replacing if this is the case. Transmission has to come out if your throwout bearing is bad, and a new clutch system installed. Approx 150 bucks for parts, and the flywheel may or may not need surfacing.
Bow Hunting
post #7 of 8 Old 09-17-2011, 02:06 PM
nembudonna
For the little bit more work and a couple of more dollars, I'd suggest haveing the flywheel done. But it's not a must do.
nembudonna is offline
post #8 of 8 Old 09-17-2011, 02:21 PM Thread Starter
newyj
thanks jeepers for the help
newyj is offline
Anybody get a screamin' deal on a used Wrangler? Post your stories! Boonking Wrangler General Discussion 35 06-02-2011 08:50 PM
Screamin Demon and Live Wires... dos0711 YJ Wrangler Technical Forum 9 10-03-2009 11:25 AM
Screamin Demon Ignition trapman TJ Wrangler Technical Forum 3 01-08-2008 02:14 PM
Screamin' Demon Coil ? anone have one? mikeyz3385 TJ Wrangler Technical Forum 21 12-26-2006 09:26 AM
screamin demon ignition fiberguy30 TJ Wrangler Technical Forum 12 10-24-2006 06:55 PM
