clutch safety switch - JeepForum.com
post #1 of 28 Old 02-26-2012, 10:58 AM Thread Starter
ymurf
1979 CJ7
What year did YJ start putting a clutch safety switch in? I just did a 94 YJ 4.0 AX15 with a Dana 300 in my 78 CJ7. I splices at the bulk head my 12v feed to dash.the ignition crank run. I wired my fuel pump up with the YJ harness that originally ran back with the VSS. But when I wired up the ignition crank I couldnt get it to do anything.I found the wire on my CJ bulk head for that but couldnt get it to crank when spliced to the YJ wire.I just ran a wire from the CJ bulk head wire straight to the starter and cranks and starts right up.Could this be a clutch safety switch problem?Did the 94 YJ have that?
Also how do I wire up my reverse lights with the AX15?
ymurf is offline
post #2 of 28 Old 02-26-2012, 11:07 AM
baritone_mike
My 88 does not need to have the clutch pushed in to start it.
If they did put one in at some point I would guess it was in 91 with the switch to the 4.0.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #3 of 28 Old 02-26-2012, 11:37 AM Thread Starter
ymurf
1979 CJ7
Originally Posted by jsawduste View Post
You got it Tom. Neutral safety switch.
From the starter relay in the PDC to the 10 pin that goes back to the fuel pump. You need to find the wire .....White with a black tracer IIRC and simply ground it.
The reverse light circuit is in there also. Simple SPST switch on the trans.. Grn/Brwn and Yel/Blk are what your looking for.
I am really simple on this wiring stuff so bare with me.I have been doing some google reading and from what I have read the YJ never came out with a clutch safety switch in a manual transmission.This right?
On the reverse light issue,I see the plug on the AX15 but how do I wire that up to make my CJ reverse lights to work?
ymurf is offline
post #4 of 28 Old 02-26-2012, 11:45 AM
jsawduste
2006 YJ Wrangler
Later models had a switch.
On the rev lights you need to connect the grn/brwn or yellow/Blk.....Whichever has voltage to one side of the switch on the trans. The other side of the switch needs a lead to you CJ reverse light wiringing.
jsawduste is offline
post #5 of 28 Old 02-26-2012, 11:47 AM
YJSteveD
My '89 doesn't need the clutch pushed in. I always do it though out of habit.
YJSteveD is offline
post #6 of 28 Old 02-26-2012, 12:30 PM
Mark05059
no YJ's have any type of clutch interupt switch stock from the factory.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #7 of 28 Old 02-26-2012, 12:57 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Nope.
Yep.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #8 of 28 Old 02-26-2012, 01:25 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
yeah my 1995 does not require the clutch in to start either.
Back Road Jeepin
BackRoadJPin is offline
post #9 of 28 Old 02-26-2012, 01:49 PM Thread Starter
ymurf
1979 CJ7
Ok I think I found the plug that went to the CJ transmission.It is a two wire plug and with the key on one side is hot.So can I just splice the two wires to the ax15 and how do I know which wire the hot one hooks to?Or am I off on this?
ymurf is offline
post #10 of 28 Old 02-26-2012, 01:52 PM
TSEJEEPERS
The neutral safety switch did not start untill the TJs came around.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #11 of 28 Old 02-26-2012, 03:17 PM
pasinbuy
Wrongggg.
Did your 93 have one when you bought it?
pasinbuy is offline
post #12 of 28 Old 02-26-2012, 03:26 PM
monkeyhouse
That's what I did with mine when I swapped in my ax-15, just spliced in the wires. Maybe post in the cj forum to make sure you have the right pair of cj wires.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #13 of 28 Old 02-26-2012, 03:35 PM Thread Starter
ymurf
1979 CJ7
I did post there this morning with no response..One wire is hot with the key on,How do I know which wire goes to which wire?
ymurf is offline
post #14 of 28 Old 02-26-2012, 03:44 PM
monkeyhouse
well, you could post up and ask for a wiring diagram, but i just used trial and error since there's only two wires. On mine there is a fuse on that so, if it's wrong, the fuse will blow.
post #15 of 28 Old 02-26-2012, 04:51 PM
WindsorRenegade
Nope. If it did I never would have gotten home when my slave crapped out on me. Had to crank that ol' girl over in second gear to get her rollin!
Originally Posted by ruthole View Post
I just bumped it around till it was in the hole and she went right in. But my hands were hard to fit in there.
WindsorRenegade is offline
clutch safety switch? cmcgrogan YJ Wrangler Technical Forum 8 12-30-2011 07:33 PM
Clutch safety switch..... SteveBad JK Wrangler Technical Forum 2 08-18-2011 01:17 PM
Clutch Safety Switch Tanner14 TJ Wrangler Technical Forum 28 03-22-2011 06:27 AM
clutch safety switch or selenoid? DeconsTructionJ TJ Wrangler Technical Forum 4 11-23-2008 07:13 PM
Help clutch safety switch! Piratejonh TJ Wrangler Technical Forum 3 11-24-2007 03:18 AM
