Clutch Replacement Write up - With Pictures! - Page 2 - JeepForum.com
post #16 of 21 Old 06-04-2012, 01:28 PM
Matt The Hammer
FSM states that you shouldn't re-use the flywheel bolts.
I'll assume it's due to the large torque applied to them when originally installed.
2013 JKU
1995 YJ
Matt The Hammer is offline
post #17 of 21 Old 06-04-2012, 02:11 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Thank you for the great writeup! this gives me courage to tackle my next clutch job! Only problem for me would be finding that clutch alignment tool, not available where I live, I may just order one and keep it for later.
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #18 of 21 Old 06-04-2012, 02:21 PM
Jims-87YJ
1987 YJ Wrangler
I thought I saw that somewhere, but almost every wright up I see appears to re-use the old one's? Does anyone know where to get replacements? Dealer?
Fernando: The Alignment tool typically comes with a new Clutch kit.
Thanks
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #19 of 21 Old 06-05-2012, 10:28 AM
Matt The Hammer
I re-used mine. Lazy.... They look like specialty bolts nontheless. So I'd assume you'd need to go to the dealer or similar joint to aquire them.
I see the Mopar flywheel bolts go for like $4 each. Should have bought these, I guess.
2013 JKU
1995 YJ
post #20 of 21 Old 12-06-2016, 09:49 AM
bryanmcadams
I'm reusing old bolts. Should I put a drop of red loc tight on them???
The 2005 2.4 liter pilot bearing is in the crank. There is a flange that the bearing backs up to thus preventing me from using a puller or the grease/bread trick. Trust me, I tried all of them. finally after two broken pullers I used a dremel tool to cut slices in the bearing and then pulled it out. Major pain, lesson learned, dremel tool worked nicely.
bryanmcadams is offline
post #21 of 21 Old 12-06-2016, 04:46 PM
Que89YJ
You need to post up to the tj guys. Different critter on the yj.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
clutch , flywheel , manual , replacement , transmission
YJ to CJ dash swap write up with pictures rrisher YJ Wrangler Technical Forum 171 05-11-2015 04:53 PM
Write up w/pictures for the 2.5l Exhaust man. Swap ? Degra101 YJ Wrangler Technical Forum 3 04-11-2012 06:10 AM
Write up and pictures for setting timing on 89 YJ I6 Cards89YJ YJ Wrangler Technical Forum 12 08-24-2010 01:41 PM
Looking for D30 axle seal replacement and Ball Joints Replacement Write Ups pfifer TJ Wrangler Technical Forum 1 04-14-2010 06:49 AM
clutch replacement write up request Rocky_Cosmark YJ Wrangler Technical Forum 2 12-28-2009 07:31 PM
