Clutch replacement 93 YJ 4.0 5 speed - JeepForum.com
post #1 of 9 Old 10-17-2008, 11:25 AM Thread Starter
Wacfrog
My slave cylinder hit the road and since I have an internal one and have to drop the tranny I'm going to replace the clutch. Which clutches are good at a reasonable price. This both my toy and everyday driver. it has a 4 inch lift with 33 x 12.50 on it, everything else is still stock. Please help a lady in distress.
Thanks
Wacfrog is offline
post #2 of 9 Old 10-17-2008, 12:02 PM
bigredcherokee
while you have that guy down I would try to convert it to external slave setup. Centerforce or Luke clutch kits are great.
For those of you in Louisiana visit
bigredcherokee is offline
post #3 of 9 Old 08-26-2011, 10:17 PM
jeepster11
I need to do the same....what brand master and slave cylinders are best...thanks
jeepster11 is offline
post #4 of 9 Old 08-26-2011, 10:42 PM
Leans93
She's my density...
Leans93's Avatar
Luk for the clutch and slave if you're sticking with internal slave. NAPA for the master. TRUST ME NAPA for the master. I went through autozone locally and clutch city online and they both sold me JUNK clutch master cylinders. NAPA was the 3rd one and finally of decent quality.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #5 of 9 Old 08-26-2011, 11:04 PM
jeepster11
Thanks for the reply...was wondering why not Luk for the master?
post #6 of 9 Old 08-26-2011, 11:13 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
LuK would be fine for the master, they're just not included in the kits like the slave is.
Centerforce clutches are an extremely poor choice for a Jeep.
Try www.carolinaclutch.com for the best pricing.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #7 of 9 Old 08-26-2011, 11:27 PM
Leans93
She's my density...
Leans93's Avatar
Yeah Luk would be fine for the master. I know they make master cylinders but I haven't ever found one for our application.
M.F. Leans
Leans93 is offline
post #8 of 9 Old 08-26-2011, 11:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
A '93 4.0L would use a LuK LMC209 master cylinder.
Max
Mean Max is offline
post #9 of 9 Old 08-27-2011, 12:18 AM
jeepster11
thanks. I will go with the NAPA master cyl and Luk for the clutch and slave cyl. I do not want to make a mistake buying lousy parts and have to pull the tranny again...thanks again for the info
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
Problem with clutch disengagement after clutch replacement (94 YJ) cslots675 YJ Wrangler Technical Forum 0 05-17-2009 07:15 PM
Fan clutch replacer (not clutch replacement) AuroraJeep YJ Wrangler Technical Forum 5 12-23-2008 02:17 PM
6 Speed Clutch Clang PSYCH0 TJ Wrangler Technical Forum 0 12-09-2008 04:23 PM
6-speed clutch noise spididle121 TJ Wrangler Technical Forum 7 04-18-2007 08:38 PM
