clutch quick connect fitting! - JeepForum.com
post #1 of 5 Old 07-23-2013, 03:57 PM Thread Starter
Exit93
Is there a way to replace the quick connect fitting so i do need to have it there. Mine is pretty mangled from the P.O and I cant get it off. I don't want to replace the plastic line if I don't need to. Is there some way to piece in a section of steel brake line from the slave to the plastic?
Exit93 is offline
post #2 of 5 Old 07-23-2013, 05:25 PM
jokerchief462
Not that I know of looks like you will end up replacing the line.
Is it leaking like it is or just look bad? If it works run it until its bad.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 5 Old 07-23-2013, 05:52 PM Thread Starter
Exit93
Its fine but I need to drop the trans and I can't get it apart
Exit93 is offline
post #4 of 5 Old 07-24-2013, 02:08 AM Thread Starter
Exit93
Maybe Mean Max can help me out?
Exit93 is offline
post #5 of 5 Old 07-24-2013, 01:40 PM Thread Starter
Exit93
Some one has to know what I can do
Exit93 is offline
