Clutch Question - JeepForum.com
post #1 of 10 Old 03-04-2002, 02:55 PM Thread Starter
gifargis
Clutch Question
Has this happened to anyone?
when the jeep is cold i.e. -10 to 10 F
My second gear pop's out.. no grinding noise just a pop and thats it.. not first, third or fourth.. when warmed up no issues...
Any ideas
I do have a 94 YJ 2.5L with 140k and clutch was replaced at 100k with a centerforce dual friction
Thanks in advance
See y'll on the trail.
gifargis is offline
post #2 of 10 Old 03-04-2002, 03:30 PM
Nine5YJ
hey
when its really cold sometimes it wont go into 2nd gear all the way.. i have to put extra effort into pushing it in.. but ive never had it pop out, once it warms up there is no problem. your linkage could be loose.
95 YJ, 31 x 12.5 ProComp ATs / AR767 wheels, stock 4.10s, 2 1/2" Rough Country Suspension Lift, and huge rusty basketball sized drain holes.
Nine5YJ is offline
post #3 of 10 Old 03-04-2002, 03:38 PM
jfarrell
I have a 90 YJ with a complete rebuild on the tranny and new clutch. My transmission went bad at 85,000 miles (3rd, 4th, and all the synchros/sliders)! I had problems shifting into 2nd and replaced the fluid and it fixed the problem. I did have it "pop" out of second even after the rebuild. Believe it or not, after the fluid change no problems. I was told by the shop that did the rebuild that they often install such a heavy weight fluid after a rebuild it causes the problems that I was having. Not sure this will help you, but you're not alone!
jfarrell is offline
post #4 of 10 Old 03-04-2002, 03:48 PM
rodgersmc
Same problem here, but doesn't have to be as cold... anything under 30 or so and I've had it happen... hard to get into second, and if i clutch in a turn or something, it often shifts itself into neutral... never had it happen with any other gear but second, and only when very cold.
Someone solve our problem! ;-)
89 YJ 4.2L
3" body lift
2" shackle lift
32" tires on 15X10's
winch
soon to be JKB2 mod
rodgersmc is offline
post #5 of 10 Old 03-04-2002, 04:33 PM
93RENEGADE
This also happens to me when it's cold, it's hard to get into second. I changed my transmission oil to synthetic and it helps a bit. I think it's just a problem with the YJ. I usually just rev it in first and shift directly to 3rd when its cold.
93RENEGADE is offline
post #6 of 10 Old 03-05-2002, 12:27 AM
kidwired
kidwired's Avatar
wut kind of lifts are u guys runnin?
perhaps linkage is binding?
I had to cut about 2" of metal out of my floor pan. but I'm SOA + 3.5 inches (9 inches total)
94 yj SOA +3.5", 35" swampers.
kidwired is offline
post #7 of 10 Old 03-05-2002, 12:46 AM
evilpsych
evilpsych's Avatar
it's sounding more like it's so cold out that the gear oil is turning to sludge.. i suggest running a thinner gear oil if you're in really cold weather most of the time.. also.. a synthetic liek mobil 1 will also fix this prob.. 75W90 is standard for most climates..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #8 of 10 Old 03-05-2002, 08:10 AM
Mike611
Mike611's Avatar
Hey Fellas,, It's not your linkage,, Its your gearweight oil.. You are probably running GL5 gearweight in your tranny,, whenever you get time,, switch to GL3 lube. This will create smoother shifting and it is all around just better for your syncros too. Put GL3 in and your good to go....
Mike,,,
95, 2.5L, custom bumpers, Flow's, 4 inch Skyjacker Super Duty, 33x12.50 MT's, 15X10 AR 767's, Hi-lift, Funk in the Trunk( two 12 inch subs ), soon to be locked and have one of those pully things on the front.
If you are going to be a bear, be a grizzly...
Mike611 is offline
post #9 of 10 Old 03-05-2002, 09:25 AM
JeepBeep
Mike, whats a good brand of GL3 to be running on?
'01 XJ BONE STOCK (Not for Looong)
'95 YJ 2.5L 3" Sus.
ProComp MT 33s"
JeepBeep is offline
post #10 of 10 Old 03-05-2002, 12:40 PM
JeeperJay
I'm switching over to GL-3 ASAP. I just got a rebuilt tranny and I'm having the same 2nd gear issues. Its fine after its warmed up but if its cold I'm lucky to get into 2nd gear at all.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
clutch question.... camper49 TJ Wrangler Technical Forum 2 09-25-2007 08:11 PM
clutch question bughunter YJ Wrangler Technical Forum 0 10-06-2006 07:46 PM
New clutch question YJfrom94 YJ Wrangler Technical Forum 3 06-29-2005 10:55 AM
clutch question Gper4life YJ Wrangler Technical Forum 6 01-02-2004 06:55 PM
