clutch question - JeepForum.com
post #1 of 4 Old 10-22-2002, 06:44 PM Thread Starter
diggedyduh
clutch question
while 4 wheeling this weekend my jeeps clutch became inoperable and i had to crank it in gear to get home, well after talking to a mechanic he said that it was the master cylinder so i changed it. Now its like i dont have a full clutch and is hard to put in gears, i need to bleed the lines again but i was told that there was a possibility that there was an adjustment shaft attached to my slave cylinder( external this is on a 95 yj, 4cyl) that applied pressure to the pressure plate and that this could be the problem. What do ya'll think??
This is for my roomate because he is computer illiterate lol thanks
90 wrangler
33X12.5x15 Firestone Destination MT ( new and very beefy), 1.5" shackle lift, custom home brewed 2" suspension lift, 258 w/ a weber carb , debating on the Hei
diggedyduh is offline
post #2 of 4 Old 10-22-2002, 06:54 PM
UglySkunk
UglySkunk's Avatar
if your master cylinder went then your slave is probably going to
91 YJ currently rebuilding
my jeep can fly can yours
if you don't know about cages or spiked tang sit down and shutup
UglySkunk is offline
post #3 of 4 Old 10-22-2002, 09:19 PM
Kev
Master of the Obvious
Kev's Avatar
I would recommend bleeding the lines again before you get too worried. When I installed mine, I thought that I had it all bled and when I first tried it I couldn't get it in gear - I then said some choice words since I didn't want to take it all apart again. Then I decided to bleed it again and as soon as I cracked the bleeder it let a bunch of air out and then worked fine.
I can't speak as to the external slave, but the internal doesn't have any sort of an "adjustment shaft." I agree with UglySkunk; I would replace both the master and the slave (especially since yours is external) since if one goes the other is probably close behind.
Hopefully it is the master and slave and not something to do the throwout bearing, clutch fork, clutch disk, pressure plate, ect. HTH and good luck!
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #4 of 4 Old 10-22-2002, 09:21 PM
Quan
Quan's Avatar
I had the same problem a few weeks ago. I had my mechanic test the master by testing it with vaccuum. It was fine but my slave was shot. I think they call it the 'clutch release' bearing or something like that. I had it all replaced and i have no problems right now. Personally, i think it was the slave in the first place cuz i had to pump my clutch to build up enough pressure to get it into gear until i had it fixed.
There comes a time... In every mans life, when decisions... have... to be made. Whether to toil, to labor, or just plain piss your days away.
Green Jeep Club Member #15
My Jeep Made Me Broke Club Member #2
93 YJ I-6 w/ stuff
Keep the greasy side down
Quan is offline
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 11:29 AM
clutch question.... camper49 TJ Wrangler Technical Forum 2 09-25-2007 09:11 PM
clutch question bughunter YJ Wrangler Technical Forum 0 10-06-2006 08:46 PM
New clutch question YJfrom94 YJ Wrangler Technical Forum 3 06-29-2005 11:55 AM
clutch question Gper4life YJ Wrangler Technical Forum 6 01-02-2004 07:55 PM
