Clutch Q?? - JeepForum.com
post #1 of 5 Old 10-23-2001, 04:08 PM Thread Starter
Jeff M
Clutch Q??
Hi,
How much (ballpark) is it for a new clutch? Is it a do it yourself project for the somewhat mechanical type?
Thanks,
Jeff
90 4cyl Wrangler
Jeff M is offline
post #2 of 5 Old 10-23-2001, 08:24 PM
walt2810
just had mine done 95 sahara (86k miles), $250 labor & $175 for clutch kit (aftermarket). the dealer wanted 370$ for clutch kit. I also had cyncros, bearings, call it a rebuild, total for the whole deal was $1000 with a 12k, 1yr warantee. Now it shifts as smooth as silk
walt2810 is offline
post #3 of 5 Old 10-24-2001, 06:35 AM
glm 87 wrangler
well cant tell ya the price,just call around
your local part stores.Just know wht kind of tranny you have.Tell them you want the clutch,
pressure plate, and release bearing.Do it all at one time save time and money!
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #4 of 5 Old 10-24-2001, 03:12 PM Thread Starter
Jeff M
thanks guys
Jeff
Jeff M is offline
post #5 of 5 Old 10-24-2001, 04:48 PM
powjunkie
I recently installed a centerforce II in my 94 YJ. If you've never done any heavy duty mechanic'n before, I would recommend having it done somewhere that specializes in Jeep work. It took me a full day to complete the job with the help of a friend. If you do decide to tackle it, better bribe a friend with beer when it's time to slide the tranny back in place....definately easier with two people. Parts for everything (clutch pressure plate, clutch disk, throwout bearing, pilot bearing, having flywheel turned) was around $250.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 09:07 AM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 08:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
