Clutch Problems after swap - JeepForum.com
post #1 of 5 Old 07-08-2013, 07:13 PM Thread Starter
90JeepToy
I have a 1990 YJ Jeep Wrangler with a 4.2L AX15 with the small input shaft. I put in a Chrysler 318 LA small block. With a bellhousing, throw out bearing and flywheel from a 92' dodge dakota 3.9L. I used the original clutch and pressure plate from the 90' 4.2L. Everything is hooked up and running but when I use the slave cylinder from the dakota the clutch doesn't work at all. I tried a bleedable slave cylinder for a 94' Jeep Wrangler 4.0 The clutch pedal feels full but it release 1" off the floor. Tried different lengths of rods in the slave cylinder to bring the clutch up off the floor more but nothing has worked. Any ideas of what I can do?
90JeepToy is offline
post #2 of 5 Old 07-08-2013, 07:34 PM
greyarea
I just got my wwap done today thith the same setup only it was a magnum 318. today must be a bad day for clutches, my new slave is leaking. mine just is starting to bite 1'' off the floor and is fully engaged with another 3-4'' of travel with 1'' of free at the top. I am using a 11'' late model 318 clutch and flywheel. What are you using for a pilot bearing?
90 YJ Magnum 5.2 v8 , 1'' BL, 1'' booms, 4" Procomp, 35/12.50-15 MTR/kevlar Ford 8.8 4.10 lsd Aussie and TJ shafts up front.
KI4UTU
greyarea is offline
post #3 of 5 Old 07-08-2013, 08:34 PM Thread Starter
90JeepToy
I bought a pilot bushing through Novak Conversions. You might not have enough reach using the 318 flywheel and pressure plate because the hat in the pressure plate is too shallow. I ruined 2 slave cylinders before figuring this out... lol
post #4 of 5 Old 07-09-2013, 11:29 PM
greyarea
What master are you using? I am using a 95 yj master with the operating rod cut off my original and welded on to the 95. The oal is about 3/8'' longer than the 95 was to start. I will check the throw of the slave but I think I just got a bad slave as the boot was wet when installed.
KI4UTU
greyarea is offline
post #5 of 5 Old 07-10-2013, 06:43 PM Thread Starter
90JeepToy
I'm using the original master. I got the clutch to work a little better by putting a 3/4" longer rod in the 94' slave driver. Seems to work it releases half way up now but it chatters a little bit when you down shift and let it out.
