Clutch problems after replacing slave - JeepForum.com
post #1 of 7 Old 08-16-2011, 07:01 PM Thread Starter
caseyjoneswys
So I just put everything back together after replacing the internal slave on my '89 YJ. After bleeding (alot) and tweaking I only get pedal pressure about every other time I press the peddle. Sometimes after pumping I can build up pressure but then it is all gone next time I go to clutch. Any input?
Thank you
caseyjoneswys is offline
post #2 of 7 Old 08-16-2011, 08:17 PM
srdart67
Are you losing fluid? If your not losing fluid that would lead me to believe your clutch master cylinder is failing.
srdart67 is offline
post #3 of 7 Old 08-17-2011, 03:46 AM Thread Starter
caseyjoneswys
Not losing fluid. I replaced the master less than a year ago (not saying that necessarily means anything). Any way to tell if it is the master or a faulty slave? Troubleshooting hints?
Thanks
post #4 of 7 Old 08-17-2011, 07:21 AM
Matt24138
Make sure the fittings are all tight. Bleed it some more. I had to bleed mine for 2 hours after replacement.
_____
/l ,[____],
l---L []llllll[]-
()_) ()_)---)_)
Matt24138 is offline
post #5 of 7 Old 08-17-2011, 07:31 AM
Matt24138
You can ake the master off and bench test it btw. When I took mine off it was leaking at the rod just a little bit. I never would have noticed until the leak got bigger. It was just enough to let air in. Also check the little o ring on the hydraulic line. They can wear out easily. As far as bench testing there ate tons of tutorials online.
_____
/l ,[____],
l---L []llllll[]-
()_) ()_)---)_)
post #6 of 7 Old 08-17-2011, 08:43 AM
Berniebikes
I just finished my internal slave replacement on an 88. I filled the slave before putting it in place and then bled the devil out of it when connected. I was careful to make sure there were no leaks anywhere. it took about a bottle of brake fluid to fully bleed it till there were no air bubbles coming out the end of the hose, only a steady stream of fluid. I could tell when normal pressure hit the pedal, it was mushy till all the air came out. Good luck! Would second the suggestion to bench test the master.
Berniebikes is offline
post #7 of 7 Old 08-17-2011, 04:37 PM Thread Starter
caseyjoneswys
Good Ideas. Thanks very much
Need Help....Replacing my clutch/slave this weekend!! jdietz92 YJ Wrangler Technical Forum 1 07-20-2011 03:13 PM
Replacing Clutch Master and Slave Cylinder Solidsolo YJ Wrangler Technical Forum 25 05-24-2010 06:49 PM
replacing clutch slave cylinder 93 4.0 Nate M YJ Wrangler Technical Forum 6 07-02-2009 08:53 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 03:14 PM
Replacing Master & Slave Clutch Cylinders Johnny World YJ Wrangler Technical Forum 5 05-17-2006 12:45 PM
