clutch problems - JeepForum.com
post #1 of 4 Old 04-12-2010, 06:48 PM Thread Starter
bigred94
clutch problems
ok so i have the internal slave cylinder in the jeep its my 3rd one so far. i keep losing fuild i think its the master cap. but the clutch pedal good every 5 or so shifts the pedal goes to almost noting then it comes back the next time i push it in. the part store wont warraty any more its the 3rd time the other ones the bleeder line blow apart. so any ideas im thinking its time for the external slave but everyone around here wants way to much for just the bellhousing and the throwout bearing. so now im not sure what to do.
bigred94 is offline
post #2 of 4 Old 04-12-2010, 07:01 PM
moonshinefuel
Keep looking for an external slave bell housing. I have an extra ax5 bell housing I'd probably give someone if they really needed It, external slave. What do you have a 6 cylinder right? It just takes time to find the deal, until then just keep making it work somehow. (I have not looked at your engine specs, I'm on a bb, and the way its set I can't see what engine you have right now but I am guessing 6 cyl.)
moonshinefuel is offline
post #3 of 4 Old 04-12-2010, 07:22 PM
Cool92yj
I went through three autozone slave cylinders in two years.
Then I finally went to the jeep dealer and bought a external slave and master cyl for $280 never had a leak since!
1992 YJ 2 Inch BDS Lift, 35 Pro Comp MT'2s, NV3550, ford 8.8,
Lockrights, Metalcloaked, built 4.0.
Cool92yj is offline
post #4 of 4 Old 04-12-2010, 07:28 PM Thread Starter
bigred94
yea its a 4.0 yea last time i did the clutch i did everything master clutch line and clutch the trannys a 92 but my yj a 94 had a 2.5 never had a clutch problem wit that.
bigred94 is offline
Clutch problems Hurley91 YJ Wrangler Technical Forum 6 12-14-2009 09:31 PM
clutch problems "double clutch shifting" propkillr YJ Wrangler Technical Forum 4 07-11-2009 12:08 PM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
More clutch problems bunkrdfool YJ Wrangler Technical Forum 15 05-21-2008 08:36 PM
Help!!! Clutch Problems!!! Help!!! sirens6 YJ Wrangler Technical Forum 4 12-08-2006 09:59 PM
