clutch problems - JeepForum.com
post #1 of 3 Old 04-07-2010, 11:27 AM Thread Starter
Unii
clutch problems
my clutch is feeling funny so i checked the fluid in the reservior my the brake booster, there is no markings on the lid and no fill lines on the inside of it.It is also close to being empty, do i need to fill it up or what?
If i do need to fill it what should i use?
Unii is offline
post #2 of 3 Old 04-07-2010, 12:03 PM
skot0123
Yep, top it off with brake fluid. You may need to bleed it as well if it has been sucking air and getting soft.
skot0123 is offline
post #3 of 3 Old 04-07-2010, 12:06 PM Thread Starter
Unii
thats what i thought thanks
Unii is offline
clutch problems "double clutch shifting" propkillr YJ Wrangler Technical Forum 4 07-11-2009 12:08 PM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
89 4.2 Clutch problems CrSublime YJ Wrangler Technical Forum 2 07-26-2006 08:09 PM
clutch problems..... YoungJeeper YJ Wrangler Technical Forum 6 11-15-2003 10:01 PM
89 yj clutch problems 2cjs YJ Wrangler Technical Forum 4 06-30-2002 03:11 PM
