clutch pedal sticking - JeepForum.com
post #1 of 5 Old 11-07-2009, 03:27 PM Thread Starter
yjman92
i have recently installed a low milage used ax-5 tranny in my yj, now i have come to find it is near impossible to drive at times because when i release the clutch pedal it does not release smoothly and seems to catch and stick making a rough transition to the release point of my clutch. please help i dont know whats wrong
yjman92 is offline
post #2 of 5 Old 11-07-2009, 04:16 PM
denmansYJ
did it start immediately after the install, or did it progressively get worse?
denmansYJ is offline
post #3 of 5 Old 11-07-2009, 04:49 PM
Lendo
When mine did that, it was in the opposite direction. Turned out to be the Master Cylinder. I may have misunderstood you though
Lendo is offline
post #4 of 5 Old 11-08-2009, 12:47 AM Thread Starter
yjman92
it progressively got worse, and at times it will be close to perfect again, thats EXACTLY what i thought it was, and i really hope it is the master cylinder, because i dont wanna pull the tranny again!! did it completely take care of the problem
yjman92 is offline
post #5 of 5 Old 11-08-2009, 06:40 AM
denmansYJ
Sounds like a master or slave cyl. issue. Try bleeding the system first. Air in the line can do funny things.
Any signs of leakage? Look on the firewall in side the cab (master) and on the ground under the flywheel (slave).
When you press and hold the clutch pedal down, does it maintain good pedal pressure or does it slowly bleed off? If it bleeds off you have a seal issue in either your master or slave cylinder.
I had an 89 XJ (2.5L, 5spd) with simular issues. Ended up replacing both the master and slave...ended up being the internal slave cylinder of coarse.
Hope this helps.
Gas Pedal sticking? greensaharatj TJ Wrangler Technical Forum 8 11-18-2009 04:17 PM
gas pedal sticking 8nine-sahara YJ Wrangler Technical Forum 10 10-31-2009 10:11 AM
Gas Pedal Sticking Joe1167 YJ Wrangler Technical Forum 6 03-12-2009 01:34 PM
clutch pedal travel/play has sticking problem kefurd06 YJ Wrangler Technical Forum 1 06-07-2007 08:23 PM
Clutch pedal sticking tr6 YJ Wrangler Technical Forum 2 08-28-2006 02:07 PM
