Clutch Pedal Return Spring? - JeepForum.com
post #1 of 4 Old 11-29-2001, 10:52 AM Thread Starter
cobra54
According to the parts breakout in various Jeep parts catalogs, a 93 Wrangler is supposed to have a clutch return spring that is 5 3/8" long. Mine does not have a return spring that I can see so I ordered one from the local Jeep dealer. I haven't received it yet but, for the life of me, I can't figure out where it goes! I believe I need it because the clutch push rod rattles like he!! against the clutch master cylinder at the slightest uneven road surface. To keep it from rattling, I have to lift up on the clutch pedal with my foot.
Please - somebody tell me where the spring goes. The rattling is driving me crazy!
93 Red YJ 2.5L
94 Red F-150 X Cab 5.0L
01 Black Cobra 4.6L DOHC
02 ZX3 Focus 2.0L DOHC
cobra54 is offline
post #2 of 4 Old 11-29-2001, 11:30 AM
Nightclaw
Hmmm... I also have a clutch pedal that rattles like a mother on uneven surfaces. I just assumed it was slop between the pedal arm and the hinge. I didn't know there was supposed to be a return spring under there, too. I'll have to look at my clutch pedal assembly tonight when I get home and see if I can figure out where that spring should go.
Nightclaw is offline
post #3 of 4 Old 11-30-2001, 10:37 AM Thread Starter
cobra54
www.4wd.com indicates that the clutch pedal return spring is for an '80 to 93'. Being a '94, yours may not have one Nightclaw. As far as that goes, mine may not have one. You know how it is on the date ranges. '81 through '92 probably all have them but some of the '80s and '93s may not, depending on when they were manufactured during the year.
93 Red YJ 2.5L
cobra54 is offline
post #4 of 4 Old 12-03-2001, 07:49 AM Thread Starter
cobra54
Finally got my clutch pedal return spring. Dealer told me it connects to the upper part of the pedal near the pivot (but above the clutch master cylinder push rod) and then connects to a "bracket" under the dash.
There's a hole in the pedal just under the pivot point just like he said, but I couldn't find anything that looked like where the other end should connect to under the dash. Here's what I did.
I pulled off the plastic panel on the instrument cluster. Looking between the dash and the left side of the steering column, you can see a direct route to where the spring attaches to the pedal. The spring can then be stretched toward the dash through this opening and hooked on to the steering column brace. It's a pretty flaky connection, so I drilled a 1/8" hole in the brace for the spring to hook through.
Worked like a champ. No more rattle and it give the clutch a much stronger feel.
93 Red YJ 2.5L
cobra54 is offline
Clutch Pedal soft, no resistance, does not engage clutch. Shivam YJ Wrangler Technical Forum 25 02-20-2017 04:10 PM
93 YJ Clutch pedal travel/master cyl return spring jb93renegade YJ Wrangler Technical Forum 7 12-16-2011 03:27 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 11:29 AM
uh oh return spring clutch fork?? kaybone TJ Wrangler Technical Forum 8 12-31-2008 03:23 PM
Throttle Return Spring LOCKED UP YJ Wrangler Technical Forum 4 01-09-2007 06:56 PM
