Clutch Pedal Assembly Difference - JeepForum.com
post #1 of 7 Old 08-23-2011, 05:57 PM Thread Starter
stenyeart
I see that the 87-90 and the 91-95 YJ's have a different clutch pedal assembly. Does anyone know the difference? The reason I ask is that I swapped a 4.0 and AX15 into my 1990 YJ and with the clutch fully depressed, the Master cylinder still has travel left in it. (The rod is not pressed all the way it. Still has about 1" of travel before it is depressed.) I am using a pre bled master/slave combo for a 94-95 YJ. Anyone have any suggestions.
I am having shifting issues, I have already replaced the master/slave and it has a new clutch kit. It is acting like I do not quite have enough throw on the clutch.
Any ideas?
stenyeart is offline
post #2 of 7 Old 08-23-2011, 06:08 PM
Matt24138
I am not 100% but I think the difference is 91-95 went hydraulic. I could be way off though.
_____
/l ,[____],
l---L []llllll[]-
()_) ()_)---)_)
Matt24138 is offline
post #3 of 7 Old 08-23-2011, 06:20 PM Thread Starter
stenyeart
My 90 was hydraulic.
post #4 of 7 Old 08-23-2011, 07:30 PM
pasinbuy
By 1" of travel do you mean that you can pick up the clutch pedal 1"? If so that is normal the pedal is not tight against the master cylinder rod.
Are you shifting ok? or What do you mean by shifting issues?
From gear to gear is it ok?
Does she go into 1st at a dead stop Ok?
pasinbuy is offline
post #5 of 7 Old 08-23-2011, 08:23 PM Thread Starter
stenyeart
Cannot put it in gear while running.
1" of travel left. When I push the clutch in, the master cylinder still needs to be compressed 1".
Shifts good with engine off.
post #6 of 7 Old 08-23-2011, 08:46 PM
clarkjdg
clarkjdg's Avatar
Just checking but are you sure you have all the air bled out real good, sounds like you may still have air in it if you have to kill it to get it in gear!
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #7 of 7 Old 08-24-2011, 05:43 AM
brentd711
I hope you resolve this and post the fix here. I'm planning to transplant a '93 drivetrain into a '90 and using the '93 clutch master.
brentd711 is offline
Clutch Pedal Assembly Billyjon1 TJ Wrangler Technical Forum 0 05-17-2011 01:31 PM
clutch pedal assembly 2xs TJ Wrangler Technical Forum 0 09-04-2010 08:35 AM
Squeaking... Possibly Clutch Pedal Assembly?? Oman Jeep TJ Wrangler Technical Forum 1 11-10-2008 02:17 PM
Brake Pedal Assembly evster5 YJ Wrangler Technical Forum 4 01-02-2006 01:45 AM
TJ pedal assembly (brake, clutch. gas) on a CJ? apachetech TJ Wrangler Technical Forum 0 08-12-2004 06:27 PM
