Clutch not disengaging after driving a bit - JeepForum.com
post #1 of 5 Old 09-05-2011, 02:32 PM Thread Starter
ja123182
My clutch doesut disengage after I drive for a while. I have a 90 yj with a 5 speed. Also my fluid was a little low and black. What's my problem...not the clutch I hope
ja123182 is offline
post #2 of 5 Old 09-05-2011, 02:50 PM
kahanabob
bleed all that black fluid out should help if not fix.........
kahanabob is offline
post #3 of 5 Old 09-05-2011, 05:23 PM Thread Starter
ja123182
Thanks do you have a link on changing the clutch fluid
ja123182 is offline
post #4 of 5 Old 09-05-2011, 06:04 PM
kahanabob
suck out the old fluid with a turkey baster and add new fluid. will need a helper, the bleeder is under on the drivers side. have helper push the clutch all the way down and hold it there then you loosen the bleeder nut and fluid will squirt out then tighten the nut then the helper can let off on the clutch. then have helper add new fluid to the master and repete the same process until you see new clear fluid squirt out of the bleeder end. do not let the master go dry. thats pretty much it!
post #5 of 5 Old 09-05-2011, 06:29 PM
ejeeperguy
1982 CJ7
The Black is the slave cylinder starting to go .Know you don't want to hear it but that's it.How old is the clutch ?I just replaced all of the clutch assembly when I mean all,I mean all .Master,slave,clutch plate,pressure plate, pilot bearing.
It was more of seeing I had the tranny down ,do it now instead of waiting to do it soon later.
As for yours not disengaging.No pressure means no plate moving.You pump the clutch to build pressure up but as you drive longer distance the pressure bleeds out.
ejeeperguy is offline
New clutch kit, master, slave cylinder NOT disengaging clutch BigOrange90YJ YJ Wrangler Technical Forum 18 08-08-2014 01:52 PM
Clutch Not Disengaging surfsup887 TJ Wrangler Technical Forum 12 03-29-2010 12:36 AM
2003 TJ 4WD disengaging while driving mebob TJ Wrangler Technical Forum 2 01-28-2009 01:13 PM
? clutch is not disengaging all the way. TylerMidthassel YJ Wrangler Technical Forum 3 12-26-2008 10:20 AM
Clutch not disengaging?? JSLRedYJ YJ Wrangler Technical Forum 6 12-01-2004 03:00 PM
