clutch master/slave cylinder - JeepForum.com
post #1 of 5 Old 06-05-2003, 12:30 PM Thread Starter
Big Blue Jeep
Big Blue Jeep's Avatar
Greetings all. Is it hard to change the clutch cylinders on your own. I dont have a hoist at all. Getting underneathe the jeep wouldn't be hard to do as it has a big lift on it. How long should it take to do the swap. A mechanic quoted me $500 canadian for parts and labor. Should i go that route instead?
1991 "Big Blue" YJ 4.0L HO
4" Pro Comp Suspension Lift
Rancho 9000 shocks in the rear
Detroit locker in the rear
33x14x15 Super Swampers Boggers (summer tires)
33x12.50x15 Yokohama Geolander MT's ('winter' tires)
Custom push bar
8,000 lb Warn winch
Custom spot lights
Cherry Bomb Muffler
ARB snorkel
Big Blue Jeep is offline
post #2 of 5 Old 06-05-2003, 03:14 PM
UPnOVER
UPnOVER's Avatar
Well you have to pull the tranny all the way out. You will need a 3 ton floor jack of what ever you can come up with. It can be done but it is not easy the first time.
I get older and they stay the same age.
RED JEEP #6
91' YJ, D30 EZ, F8.8 locked & 410's, BDS4+" lift, 35" BFG's on 15x8 RC, 8,000lb Ramsey, etc.
rock-nutz.com
UPnOVER is offline
post #3 of 5 Old 06-05-2003, 04:23 PM
Karnage
I just did all of this work myself. It is easy however it is a pain in the arse to put the tranny back in. Have them do it for 500$ and also do ur clutch and flywheel at the same time
Putting the tranny in u will need Three jacks to level the tranny the out put is long
And hey there dude I am canadian too but in LA eh!
Karnage is offline
post #4 of 5 Old 06-06-2003, 05:52 PM Thread Starter
Big Blue Jeep
They flywheel and clutch are in awesome shape already. I think it would be easier to let the mechanic do the job. Dude, how do you like LA eh?
Custom push bar
8,000 lb Warn winch
Custom spot lights
Cherry Bomb Muffler
ARB snorkel
post #5 of 5 Old 06-07-2003, 01:02 AM
paulchilds
paulchilds's Avatar
It's not difficult in a "technical" sort of way, just in a "crawling around on your back under the jeep for hours getting dirty" kinda way.
If you already have a buddy, a jack, and a weekend, go for it! Cost for the parts should only be around $150-$200, so you'll save quite a bit of money.
2000 XJ 6 cylinder, 5 speed manual
Rusty's 3" lift (rear add-a-leafs)
JKS Quicker Disconnects
31" Wrangler WorkHorse Extra-Grip on stock wheels (painted black)
paulchilds is offline
clutch master cylinder verses the slave cyl Ctskip YJ Wrangler Technical Forum 4 02-20-2009 08:45 AM
Clutch Slave and Master Cylinder replacement jonner YJ Wrangler Technical Forum 13 08-03-2006 10:58 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 09:37 AM
Master/slave clutch cylinder replacement 95 SaucerBoy YJ Wrangler Technical Forum 15 08-15-2005 05:13 PM
Help: Clutch Master Cylinder/Slave Connection Kev YJ Wrangler Technical Forum 6 08-09-2002 12:19 PM
