Clutch master cylinder replacement - Page 5 - JeepForum.com
post #61 of 108 Old 08-26-2010, 10:18 AM
AmnWatkins
Thank you, i appreciate your help.
Check the air tires, thats where the power is generated.
AmnWatkins is offline
post #62 of 108 Old 06-05-2011, 08:46 PM
aar
I too have a leaking Master that required some refill in order for the clutch to operate properly.
After some debate (not much) I took Opihi59 advice and ordered the Master/Slave/line combo from rockauto (Max's advice).
I got the part and plan to install it next week. My question has to do with the bleeding of the system.
What would the proper/easiest way of doing it? It has No bleeding screw.
Also what would be the best sequence to install? Slave or Master first?
Thanks for all the help.
aar is offline
post #63 of 108 Old 06-05-2011, 11:50 PM
dwdrums40385
most have a bleeder screw down by the slave cylinder, but good luck getting it loose, most are pretty much gone by the time you actually need to use it.
1993 YJ 4 banger- cold air intake, 31" matercraft MT's, 1" boomerang shackles, bedlined rockers, Proline beadlock simulator rims, bedlined shorty corner guards, Bed lined tub, homebrew power steering skid, LUK stage II performance clutch.
dwdrums40385 is offline
post #64 of 108 Old 06-06-2011, 11:19 AM
andybloch1
The 93 is different than the 95. 93 has a bleeder right by the bell housing. If you bought the kit you should not need to bleed.
andybloch1 is offline
post #65 of 108 Old 06-06-2011, 11:46 AM
aar
Should have specified. I have a '95 with a 2.5L. The new slave unit has no bleeder screw.
aar is offline
post #66 of 108 Old 06-06-2011, 12:16 PM
monkeyhouse
I am pretty sure Opihi59 did a writeup on adding a bleeder to one of those kits one time. They are not supposed to need bleeding though, lol. I will see if I can find it on a search.
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
post #67 of 108 Old 06-11-2011, 08:32 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
No bleeding required. The combo kits are full of fluid & pre-bled. Install it all at once.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #68 of 108 Old 06-11-2011, 08:55 AM
aar
Max
Yes, the fluid was included. In mine it came spilled all over the box. No big deal. I refilled it and bled it on the bench.
Works great, never new what the pedal pressure was supposed to be till now
aar is offline
post #69 of 108 Old 06-24-2011, 08:40 PM
d-dub
94 External Slave
Max
I just replaced the Clutch Master/Slave asm in my 94 YJ with the Made in USA unit from Crown Automotive (through Quadratec). It has a bleader screw on the slave, same as the stock original. It came empty, no oil in it. So, I started to blead it... Pumped some DOT 3 fluid into it to get it started... and let it drip for a couple hours keeping the master full... put the plug in... And, still no pressure??? Ran out of time tonight, have to work tomorrow, so I will try to blead it again sunday...
Also, on the tip of the slave cylinder. There are thin plastic straps going from the cap to the mounting flange??? I left them there, thinking they will help make sure the rod stays positioned in the pocket on the clutch release lever and would brake off the first time the slave is stroked??? Any one have a comment on if I should have cut them off???
d-dub is offline
post #70 of 108 Old 06-24-2011, 09:11 PM
monkeyhouse
sounds like you are gravity bleeding it, which is a good idea(especially when it's on the work bench). Try having a helper push the pedal to the floor and hold there, then you loosen the bleeder valve(best to have a jar for any fluid that comes out to go into) and listen/watch. Once it finishes tighten, then helper can release pedal. If there is still air in there, you will here it pop out. If you do have air, you may have to repeat that process many, many times to fully get all the air out. In my experience I had to fill the reservoir after two bleeds, so keep an eye on the fluid level.
As for the straps, they are just what you thought. You were correct to leave them alone.
post #71 of 108 Old 06-26-2011, 07:46 PM
d-dub
Thanks a lot. I didn't get a chance to get to it today. Maybe, tomorrow.
d-dub is offline
post #72 of 108 Old 06-28-2011, 05:50 AM
d-dub
Got it. It is a lot easier to do with a helper. I tried bleading the system myself... Arms just aren't long enough to push on the pedal and open the bleader screw...LOL... A little help from my wife and 12oz of brake fluid, only took 20 minutes to get it back to new...
Thanks, DW
d-dub is offline
post #73 of 108 Old 06-28-2011, 01:31 PM
monkeyhouse
Thanks, DW
so your pedal is good now? Great news.
post #74 of 108 Old 06-28-2011, 08:29 PM
d-dub
Yeah, I was trying to do it myself. With the Master/slave installed in the vehicle and I must have been getting air back in before I could close the bleader... Not to mention I couldn't get a full stroke of the pedal with my finger tips while laying on the ground under the Jeep. With a helper it didn't take long at all.
PS Thanks for confirming I didn't need to remove the straps before mounting the slave...
d-dub is offline
post #75 of 108 Old 06-28-2011, 11:02 PM
monkeyhouse
hey man, we are all in this together, someone told me, which is why I told you. BTW, I have had better success in the driver's seat, with boots off bleeding the clutch by myself.
Clutch Master Cylinder Replacement biasdesign YJ Wrangler Technical Forum 5 07-28-2009 06:27 AM
'88 YJ clutch master cylinder replacement BlackSheep92 YJ Wrangler Technical Forum 0 05-05-2008 09:42 AM
Clutch Slave and Master Cylinder replacement jonner YJ Wrangler Technical Forum 13 08-03-2006 09:58 PM
Need you thoughts on Clutch Master Cylinder replacement Johnny World YJ Wrangler Technical Forum 7 05-19-2006 05:38 PM
clutch master cylinder replacement ? freakydiver YJ Wrangler Technical Forum 6 02-20-2006 04:30 PM
