Clutch master cylinder replacement - Page 4 - JeepForum.com
post #46 of 108 Old 06-20-2010, 12:47 PM
jsta6
OK, I got the snap-ring in correctly this time. I couldn't see the three groves that it needed to fit in to, so it kept coming out.
Now I am getting an intermittent hard clutch pedal. Meaning, the clutch pedal won't go in or I have to "double pump" (I have sometimes heard it called). Wife said she was getting this before, but it is happening more often now. I am ASSuming this is what caused the snap-ring to come out in the first place - Wife had hard clutch pedal and she jammed on it really hard on an angle and the snap-ring popped out.
So, now, do I need to replace the MC / slave cylinder system or is there a fix I don't know about? (fluid level is fine).
TIA!
Shawn
93 YJ - wifes daily driver
97 Chevy conversion van - wifes taxi for the kids...
87GN daily driver...my only car, driven EVERY DAY!
1985 Olds 442 - POS basketcase rustbucket - lowrider...
"There's good in everybody. Boost. Don't knock." Author:Warren G. Harding
jsta6 is offline
post #47 of 108 Old 06-20-2010, 03:48 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Shawn, try reading this thread!
http://www.jeepforum.com/forum/f12/c...h-help-853773/
In my opinion that is what you have going on.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #48 of 108 Old 06-20-2010, 04:56 PM
jsta6
Max
Thank you sir.
Going outside now to feel / listen for click...
Is this the correct part:
DORMAN Part # CC649002 {#52104113}
$102 at rockauto...
Shawn
jsta6 is offline
post #49 of 108 Old 06-20-2010, 05:00 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by jsta6 View Post
Thank you sir.
$102 at rockauto...
That part is for the master/line/external slave combo. Do you have an internal, or external slave? Also what is the year, engine, etc. of the YJ in question?
Max
Mean Max is offline
post #50 of 108 Old 06-20-2010, 05:01 PM
jsta6
Max
oooooh...crunchy...yep, that must be it. Must be the broken spring. Wasn't sure at first, but I had #1 son press the clutch pedal a bunch of times and sure enough it feels like someone put a bunch of broken glass in there...
Shawn
jsta6 is offline
post #51 of 108 Old 06-20-2010, 05:09 PM
jsta6
Max
1993. 4.0L. May 1993 on the door sill plate.
Has the "roll-pin" style MC line.
External slave.
Shawn
jsta6 is offline
post #52 of 108 Old 06-20-2010, 05:18 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
External slave.
Shawn, the external slave was not introduced until '94, but many '93 & previous models have been retrofitted. If you're sure that it's an external slave, that part number you listed from RockAuto Auto Parts should be correct!
Max
Mean Max is offline
post #53 of 108 Old 06-20-2010, 08:51 PM
jsta6
Max
ooooooo k.
I see now. I ASSumed it was an external slave because I thought that if I had a roll-pin style MC, that I had the newer style system. (thought I read that somewhere) I see now that just because I have the roll-pin style MC, it doesn't mean I have an external slave. My slave is in fact "internal".
Uploaded with ImageShack.us
So, I just need to replace the MC. And to get the line off of the MC, I need to drain the fluid, put the MC on its side, and knock the roll pin out as mentioned before, correct?
Shawn
jsta6 is offline
post #54 of 108 Old 06-20-2010, 08:56 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I knock the pin out while the master is still installed, then disconnect the rod at the pedal, and then remove the two bolts that attach the master cylinder last. Reverse the procedure for installation.
Bleed the system at the bleeder valve located here.
Max
Mean Max is offline
post #55 of 108 Old 06-20-2010, 09:17 PM
jsta6
Max
Hmmm...I thought that if I tried to knock the rod out with the MC still installed, I might break the body (the long plastic part of the MC that is between the reservoir and mounting plate). But come to think of it, who cares if it breaks???...it's broken anyway...
Thanks.
Shawn
jsta6 is offline
post #56 of 108 Old 06-20-2010, 09:21 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
The pin usually isn't that difficult to remove. A small blunt pin punch will get it right out.
Max
Mean Max is offline
post #57 of 108 Old 06-21-2010, 05:37 AM
jsta6
Max
Got it, thanks!
Shawn
jsta6 is offline
post #58 of 108 Old 07-06-2010, 01:20 PM
jsta6
Sorry for not posting sooner.
Yes, that was the problem, the spring was broken in side the MC. New swap was super easy.
Thanks!
Shawn
jsta6 is offline
post #59 of 108 Old 08-25-2010, 10:50 PM
AmnWatkins
Okay, I need to correct myself.
Loosen the set screw, not the line, at the slave.
I'm at work and I was rushing to try to answer. My apologies!
Max
Where exactly is said set screw on the external slave? I have a '94 where the rod is broken loose at the firewall and brake fluid running down my floor board like in your example, it's time to replace it.
Thanks for any help, it is very appreciated.
Also, Max, I'm in awe of your vast knowledge on this and every other thing Jeep.
Check the air tires, thats where the power is generated.
AmnWatkins is offline
post #60 of 108 Old 08-26-2010, 12:55 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Set screw--bleeder screw in the bleeder tower on top of the external slave. Tower shown here:
Set screw removed here:
And yes, Max rocks.
And here it is in the tower:
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
Clutch Master Cylinder Replacement biasdesign YJ Wrangler Technical Forum 5 07-28-2009 06:27 AM
'88 YJ clutch master cylinder replacement BlackSheep92 YJ Wrangler Technical Forum 0 05-05-2008 09:42 AM
Clutch Slave and Master Cylinder replacement jonner YJ Wrangler Technical Forum 13 08-03-2006 09:58 PM
Need you thoughts on Clutch Master Cylinder replacement Johnny World YJ Wrangler Technical Forum 7 05-19-2006 05:38 PM
clutch master cylinder replacement ? freakydiver YJ Wrangler Technical Forum 6 02-20-2006 04:30 PM
