clutch master cylinder replacement ? - JeepForum.com
post #1 of 7 Old 02-18-2006, 01:58 PM Thread Starter
freakydiver
I'm in the process of replacing my clutch master cylinder, got everything undone and disconnected except for the connector at the clutch itself. Its the black quick disconnect - one long black cylinder and then a little, larger in diameter 2nd cylinder at the one end. How does this quick disconnect come undone? Mine barely moves at all - maybe a millimeter tops.
Thanks
freakydiver is offline
post #2 of 7 Old 02-18-2006, 02:40 PM
vdubstreets
thats funny i just did mine, like not even an hour ago, did u dissconnect it from the clutch pedal itself?
if you have aim ... mine is dkblaze69 i can help you out.
vdubstreets is offline
post #3 of 7 Old 02-18-2006, 02:53 PM Thread Starter
freakydiver
yah - the pedal side is the easy side. I'm talking about the connection where the hose from the master cylinder goes into the tranny housing itself. How does that black cylindrical quick disconnect come off? Or does the hose come off of the master cylinder itself?
post #4 of 7 Old 02-19-2006, 02:05 AM
SwearingYeti
SwearingYeti's Avatar
okay there should be a "wrapped nail" style thinger that goes through the brass into the cylinder, take a nail and a small hammer and just tap it out. it should come out rather easily. it looks like a burrito wrapped up like 4 times and its really small and shiny good luck. Just a reminder, dont push the clutch in until you have all the fluids replaced so you wont have to bleed it. I learned the hard way
1991 Red YJ - 2.5L
1988 Red YJ -304ci
1989 OD XJ- 4.0L
SwearingYeti is offline
post #5 of 7 Old 02-19-2006, 06:56 AM
YJBlues
YJBlues's Avatar
That wrapped burrito is called a roll pin , the new master cylinder should come with a new o-ring and roll pin in a small bag.
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #6 of 7 Old 02-20-2006, 09:01 AM Thread Starter
freakydiver
Thanks guys - according to my jeep manual, you are supossed to disconnect the hose from the tranny housing - I just went and bought a new clutch master cylinder and it didn't come with that cabling anyhow so yah I just removed the roll pin and the hose from the master cylinder itself.
Quick question on bleeding the system. I imagine it should go something along these lines - have someone press in the pedal - open the release valve, let bleeding occur, close release valve - pump pedal a few times and check play. Does this sound correct to you all? I take it I'll have to do this a few times...
Thank for your help guys.
post #7 of 7 Old 02-20-2006, 04:30 PM
azgurney
You are correct, bleed it just like brakes. I do not pump mine between bleeding. It took quite a few times to get all the air out of mine. I hope you used a original equipment master cylinder or you will be replacing the master cylinder in a year or two. Ask me how I know?
91 Wrangler 4.0 5sp
8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows
azgurney is offline
Clutch master cylinder replacement Mean Max YJ Wrangler Technical Forum 107 09-26-2014 03:06 PM
Clutch Master Cylinder Replacement biasdesign YJ Wrangler Technical Forum 5 07-28-2009 06:27 AM
'88 YJ clutch master cylinder replacement BlackSheep92 YJ Wrangler Technical Forum 0 05-05-2008 09:42 AM
Clutch Slave and Master Cylinder replacement jonner YJ Wrangler Technical Forum 13 08-03-2006 09:58 PM
Need you thoughts on Clutch Master Cylinder replacement Johnny World YJ Wrangler Technical Forum 7 05-19-2006 05:38 PM
