Clutch issues after replacing - JeepForum.com
post #1 of 8 Old 09-30-2011, 09:39 PM Thread Starter
cshocker
Hi I'm super new to the jeep world and community, so bear with me here please.. Seems like this is the only place I can get some answers. Im just gonna start from the beginning here... Yesterday I installed a whole new clutch kit. Put everything back together. Bled the clutch, had pressure. Pressed on the clutch and the line from the slave to the master popped off, realized the quick disconnect inside that line was all messed up. Today I replaced that. Bled the line...AGAIN.. but now all of a sudden the fluid stopped going into the line, none is coming out when i open the bleed valve? Absolutely no pressure when I press the clutch pedal down.. AND my starter is whining like crazy.. Even gave a good "zing" when I started it last.. Someone PLEASE help me.. Thanks in advance..
cshocker is offline
post #2 of 8 Old 09-30-2011, 10:50 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Welcome to Jeep Forum.
Give us some info/specifications. Tell us what year vehicle you have, what engine/trans etc so we can direct the responses. Fill out your profile etc.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 8 Old 09-30-2011, 11:28 PM Thread Starter
cshocker
Yea i guess that would help huh? I have a 93 wrangler 2.5 4cyl not exactly positive of the model of transmission?
cshocker is offline
post #4 of 8 Old 10-01-2011, 12:56 AM
Opihi59
Opihi59's Avatar
You have an AX 5. Being a 93 that also means you have an internal slave. Lucky you. So what end popped off? The quick disco down by the trans? I am guessing you changed out the internal slave as part of your repair job. Do you have any fluid leaking? The pressure required to activate your new internal slave may have been more than your clutch master could activate, and subsequently your master died. Occasionally they will leak down the inside of the firewall inside the passenger compartment as a sign of failure. You may find you need to replace the master now, refill and bleed, etc.
What is going on with your starter? It sounds like the starter drive is not engaging into the flywheel. Provided that you replaced any shims on it, it doesn't seem that simply removing it and bolting it back in would make it fail unless it was really on its way out. Make sure your grounds and connections are good and let us know what a zing is.
Opihi59 is offline
post #5 of 8 Old 10-01-2011, 10:12 PM Thread Starter
cshocker
Ya the quick disco that connects to the slave (which I did replace) is what kept popping off. The last time it lost pressure My buddy that was helping me bleed it said it did leak even tho the line we were having issues with (from the slave to master) was still connected and he didn't know where it was coming from. This was on the engine side of the firewall. The reservoir was completely full still tho,? Could this mean my master went out? Or maybe there's a vacuum lock not allowing the fluid to go down the line therefore causing my clutch not to have pressure? And as far as the starter, after making a horrendous sound it sounded like it just kept spinning when it should have stopped? Not like the noise when you turn the ign when it's already running but more like the starter gear is spinning, rubbing on something after my jeep is started. Unfortunately my jeep is at a friends house and I'm just trying to get as many ideas as I can before I go back over there in a few days to give it another go..
cshocker is offline
post #6 of 8 Old 10-02-2011, 01:52 AM
Opihi59
Opihi59's Avatar
Difficult to tell, but it does sound like the Master pooped out. Is the starter drive not completely disengaging from the flywheel? You put everything back same way it came off, right?
Opihi59 is offline
post #7 of 8 Old 10-02-2011, 09:39 AM
Foundrydude
Sounds like you need a new clutch master and another starter. The zinging sound is the bendix sticking, which keeps the gear in contact with the flywheel instead of retracting. If you used the wrong bolts the gear fit might be too tight and causing the bendix to stick.
good luck
Foundrydude is offline
post #8 of 8 Old 10-02-2011, 12:05 PM Thread Starter
cshocker
Thank you very much guys.. I'll be goin back at it on Tuesday and I'll let you know how it goes!
cshocker is offline
