clutch issue maybe? please help - JeepForum.com
post #1 of 3 Old 04-05-2010, 01:21 PM Thread Starter
surfer311
about a week ago it became difficult to get my clutch into gear but once i got down the road a few minutes all problems went away. a few days ago the problem kept occurring no matter where i was or what gear i was in. i parked it overnight and went to move it the next morning and could not get it into gear without having the jeep turned off. now i cannot switch gears when turned on and jeep will move on its own if in gear regardless of the clutch pedal fully engaged or not. the only way you can stop it is by applying the brake or turning it off. any advice or ideas would be greatly appreciated.
surfer311 is offline
post #2 of 3 Old 04-05-2010, 01:28 PM
95Turtle
Sounds like a bad slave cylinder. Sometimes with just a slow leak they will "pump up" after using the clutch a little bit, like brakes that are low on fluid. That's probably what you experienced a few days ago-- now it's just worse.
95Turtle is offline
post #3 of 3 Old 04-05-2010, 03:18 PM Thread Starter
surfer311
i can press the clutch pedal all the way to the floor and back and it doesnt recognize that im pressing it. it's a 93 2.5L wrangler if that helps.
clutch , jeep , release bearing , transmission
transmission issue ? drive shaft issue ? clutch issue..where to begin ?..... rthompson48082 YJ Wrangler Technical Forum 7 09-28-2009 05:07 PM
Clutch Issue Mol YJ Wrangler Technical Forum 4 06-10-2009 09:40 AM
Clutch issue / bleeding clutch. Dravintoad TJ Wrangler Technical Forum 7 11-12-2007 11:50 AM
Clutch Issue Lyfisin TJ Wrangler Technical Forum 0 12-08-2006 07:40 AM
Clutch issue... underwhelmd YJ Wrangler Technical Forum 5 12-05-2006 03:06 PM
