Clutch issue? - JeepForum.com
post #1 of 14 Old 08-15-2011, 05:56 PM Thread Starter
Yjmudding
Clutch issue?
Let my friend drive my 92 yj 5 speed standard and when I got it back it will grind going into 3rd and 2nd gear but only when I downshift. I want to find out what is wrong before I replace something I don't have to. Please help!
Yjmudding is offline
post #2 of 14 Old 08-17-2011, 09:45 PM Thread Starter
Yjmudding
Someone help?
post #3 of 14 Old 08-18-2011, 12:23 AM
MiNiSaBa
Your friend drove your yj like a sports car... NOT GOOD. Synchros or gears might be going bad. Downshifting a yj can not end up with good results.
MiNiSaBa is offline
post #4 of 14 Old 08-18-2011, 12:32 AM
cubewhiz
sounds like worn synchros to me
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #5 of 14 Old 08-18-2011, 06:53 PM Thread Starter
Yjmudding
What are synchros?
post #6 of 14 Old 08-18-2011, 07:00 PM
oldtime_ironman
Originally Posted by Yjmudding View Post
What are synchros?
Synchros are parts inside the trans that help the gears line up so you can shift. If they wear out, the gears won't line up just right, and they will grind against each other. It's basically a transmission rebuild.
oldtime_ironman is offline
post #7 of 14 Old 08-18-2011, 07:28 PM Thread Starter
Yjmudding
But it only grinds when I downshift and only in third and second gear
post #8 of 14 Old 08-18-2011, 07:44 PM
oldtime_ironman
Give it time, I'm pretty sure the grind will get worse eventually. Meanwhile, I would go real easy when you shift, try to "feel" when the gears are gonna "snick" in and line up. Try to match speeds pretty close.
post #9 of 14 Old 08-18-2011, 07:51 PM Thread Starter
Yjmudding
I've gotten pretty good at getting it right with almost no grinding. But how to I go about fixing it?
post #10 of 14 Old 08-18-2011, 08:03 PM
oldtime_ironman
Mean Max has the most awesome write-up about how to. With pics of everything. Look here:
http://www.jeepforum.com/forum/f12/m...ebuild-1032480
He's the resident expert at transmission stuff. Big time.
post #11 of 14 Old 08-18-2011, 08:10 PM Thread Starter
Yjmudding
Thanks for that link. That looks too confusing but my friends dad works on transmissions so I'll have him fix it in return for some work I can do for him. Thanks for the help everyone!
post #12 of 14 Old 08-18-2011, 11:29 PM
cubewhiz
This is a synchro ring.
and a whole synchro hub.
and here you can see them located sporadically in the transmission (look for gold). This isn't the same transmission as you have, but the idea is the same.
Those gold synchro rings wear down. When you buy a rebuild kit, it comes with new rings. The parts are cheap (only a couple bucks a piece). It's the amount of work involved that makes the job a pain in the ***.
cubewhiz is offline
post #13 of 14 Old 08-18-2011, 11:37 PM Thread Starter
Yjmudding
Thanks for those pics. That looks a lot less confusing than he pictures in the other link I looked at
post #14 of 14 Old 08-18-2011, 11:53 PM
cubewhiz
Haha, yes. Well, what I showed you was a 1974 GM SM465. It's a 4 speed transmission with a main case and the gears go inside, disassembled by removing the top shift cover. The AX-15 has three major pieces so the rebuild proceeds a bit differently, but you get the idea.
The point is that the synchro ring has teeth on it. The teeth line up with the hub assembly and allow the shift fork to move the slider, thus engaging a different gear. When those rings are worn, you hear grinding as you shift and shifting is no longer smooth.
I have a Mitsubishi FM146 sitting in my driveway with 4th gear synchros shot to hell that I've been meaning to check out.
cubewhiz is offline
