#1 | |
clutch install writeup?
hi, we are about to install a new transmission, but neither me nor any of my friends have ever installed a clutch. Does anyone know where there is a writeup we can look at?
92 YJ 4" Rubicon Express suspension lift Boomerang Shackle Lift SYE with CV shaft |
#2 |
Vendor
Get a Haynes or Chilton manual. If you are unable to buy one, go to the public library and look there; copy the pages you need. And please, please...use a torque wrench.
Brown Dog Offroad http://www.browndogoffroad.com The Jeep Forum Discount is ON!! Join our FaceBook group Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep 100% MADE IN AMERICA OFFROAD-REVIEW of Browndog Superkit 91YJ 2.5 Brown Dog Mounts and Engine Brackets (Serial Number 1) 2" BL 3.5" Superlift SL AA SYE 35" BFG Mud Terrains Bulldog front bumper Best Top seats "Family" roll bar 25 foot 1/2" log chain No Top, No Doors (Best Top Safari) |
#3 |
If you can change the transmission the clutch isn't hard.
Take out the bolts and it will fall right down along with the pressure plate. Once it's down remove the flywheel and have it cut. A clutch shop will sell you a shim to put behind the flywheel and bring it out to it's original thickness. A shop that has a flywheel machine probably won't and you sould ask how thick the wheel is supposed to be, how much is taken off already, and get the correct shim. Bolt the flywheel back up using a torque wrench Install the clutch disk and pressure plate with the included alingment tool, again use a torque wrench. Than's it. |
#4 |
I actually just installed a clutch something i've never done before and it was relatively easy just make sure that the clutch is centered and that you do use a torque wrench.
chris
1993 Jeep Wrangler 4.0L Tom Woods rear HD shaft D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,5" BDS, homemade greasable boomerang shackles, SS braided lines, rubicon flares, 1" prothane body lift, 35" TrXus M/T, smitty built XRC, armor and a paint job soon to come. |
#5 |
I found that the hardest part was adjusting the transmission on the jack just right to slip the input shaft through the clutch and pilot bearing. Just don't force it, and take your time. I threw a few cursing fits during, but i'm glad I did it right.
Also, I found on the 4cylinder that if you unbolt the exhaust downtube from the header, it gives you alot more space to work. Not sure about the 6cylinder though.
[CENTER][SIZE="1"]1990 Jeep Wrangler YJ 2.5L "four-banger" 4" suspension lift 33" BFG A/T Reman NP231 Custom Fab Front and rear bumpers.[/SIZE][/CENTER] |
#6 |
I just did mine, its easy ... but now I have to pull it all apart again and put a new pilot bushing in cause i ****ed this one up when i put it in .... Should of takin my time and did it right
1990 YJ I6 258 AX-15 NP 231 *Now with Posi-Lok* 5 Inch BDS Lift 33X13.50 Mickey Thompson BaJa Claws Early YJ club member #29 |
#7 |
If you are going to reuse your pressure plate, make sure that you put alignment marks on the flywheel and pressure plate so that it will match up properly when you put it back together.
Mike 2006 TJ X (Stock - w/ Borla Cat-Back Exhaust) Built a YJ from the ground up: - '04 4.0L (4,000 miles), NV3550 (0 miles), NP231 w/ HD SYE (9,000 miles), 33x12.50x15 Pro-Comp AT's, HP D30/8.8 (4.56 gears), ARB Lockers front and rear w/ compressor, hard/soft tops, full/half doors. -----> Build thread can be read here: http://www.jeepforum.com/forum/f12/yj-build-plan-259306/ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
