Clutch hydraulic line grommet- where to get? - JeepForum.com
post #1 of 3 Old 08-19-2011, 09:28 PM Thread Starter
linderblock
Missing the gromment around the clutch hydraulic lines going into the bell housing. Have not gone to dealer just cuz it's difficult to find the time. Hoping to find one on the internet but my searches have not found any. 1990 YJ 4.2L. Anybody know of a place to look?
linderblock is offline
post #2 of 3 Old 08-20-2011, 06:28 AM
1SASjeepster
If you can't locate one, you can very simply make one from a piece of sheet rubber and RTV silicon. Cut the size you need larger than the hole, at least and inch. Make a slit in it so it will go around the tubing, also a hole a little larger than the diameter of the tubing. Clean off the bellhousing where it goes and silicon it in. RTV works great and that should hold without any problem.
Take care,
1SASjeepster is offline
post #3 of 3 Old 08-20-2011, 06:37 AM Thread Starter
linderblock
Great idea. Thanks
hydraulic clutch line vansboarderx YJ Wrangler Technical Forum 6 03-21-2011 06:19 PM
Need a 94 yj clutch hydraulic line! Help..... midnightc2 YJ Wrangler Technical Forum 5 01-20-2010 12:43 AM
93 Clutch hydraulic line shamsun YJ Wrangler Technical Forum 1 11-07-2008 10:51 AM
Hydraulic Clutch Line Flat Black YJ Wrangler Technical Forum 8 03-08-2007 04:19 PM
Hydraulic clutch line DaOne TJ Wrangler Technical Forum 2 07-05-2006 10:20 AM
