Clutch is going.. GOING... almost gone.. - Page 2 - JeepForum.com
post #16 of 18 Old 12-16-2011, 01:28 PM Thread Starter
Xpress
I just bought another unit from autoZone to get by for now. Put it in and tried to see if it would hold pressure, guess it didn't like that because it blew wide open. Good thing they said they would exchange it for a new one...
For $70 though it'll get me by until i can convert to an external slave cyl setup.
All about that unibody life.
Xpress is offline
post #17 of 18 Old 12-17-2011, 12:31 AM
metalry101
metalry101's Avatar
Okay...mine has a similar issue now. Some time this summer...May or June I think it was...one of the little U shaped clips that held one of the pressure lines (don't remember if it was the bleed line or the one from the master cylinder) fell out of my slave cylinder, causing the clutch to lose pressure and completely stop functioning. Even though the old slave cylinder looked to be just fine, I bought a new one from Autozone and installed it. Well...my clutch has felt kinda sketchy lately so tonight my dad and I were bleeding it again to make sure that wasn't the issue when BAM!!, pedal to the floor and brake fluid running out of the front of the bellhousing. Obviously something else could have happened, and until I get time to rip the transmission out of the Jeep again I won't know for sure, but I'm guessing that the pressure line retainer clip fell out again.
Has anyone else ever experienced this problem? If that is the problem and not a defective or blow slave cylinder, wouldn't a hose clamp or something around those little U shaped clips work to keep them in? I don't really have a desire to spend $400 or something ridiculous on a clutch that's going between a gutless four cylinder and crappy transmission, but I don't really have a desire to pull the tranny again either, especially not soon...
'90 YJ - Squirrel powered and on 35's!
Utah Jeepcrew #26
metalry101 is offline
post #18 of 18 Old 12-17-2011, 11:25 AM
ejeeperguy
1982 CJ7
I have the same thing going on with mine.Seems to hold for awhile then it starts to leak and loose pressure.what's worse is I was hurt in the desert but put it in for the wife.So all that pain and suffering for nothing.
ejeeperguy is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 09:07 AM
Need new clutch slave/master cylinder: Quadratec or clutch city online? Links inside myoung YJ Wrangler Technical Forum 3 08-23-2010 05:49 PM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
