Clutch is going.. GOING... almost gone.. - JeepForum.com
post #1 of 18 Old 12-14-2011, 11:59 PM Thread Starter
Xpress
So just over a year ago, me and my dad replaced the slave clutch cyl in the Jeep with an AutoZone one. It worked great, but recently I have been noticing me having to add fluid to it all the time to keep it working. Bled it off today and it worked like new, until I got in it to drive this afternoon and discovered just how loose it was. Checked the reservoir and it's pretty much empty.
So guess it's time to replace it again. Shouldn't be hard, already done it TWICE.. (had to pull it apart from not connecting the hydro lines properly)
The question is what does everyone recommend for a good replacement? Do I pony up and buy the OEM one? Or is there a good aftermarket one that isn't as much as the OEM? I noticed quadratec has one with a warranty on it, OEM replacement:
http://www.quadratec.com/products/52004_01.htm
All about that unibody life.
Xpress is offline
post #2 of 18 Old 12-15-2011, 12:06 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
OEM or Napa pre-bled. Autozone and Kragen MC parts are garbage. I know this firsthand. When you buy the slave, buy another master and make sure they're metal, not all plastic.
Luck Favours The Prepared
Anticanman is offline
post #3 of 18 Old 12-15-2011, 10:15 AM
hdfxrs91
1987 YJ Wrangler
I got mine from Advance and it lasted for the time it took me to put the transmission back in. Yep, it was defective. I took it back and ordered a Sach's kit for just a few dollars more and no shipping charge. Haven't had one problem...
hdfxrs91 is offline
post #4 of 18 Old 12-15-2011, 10:23 AM
mudphish
I just replaced mine with one from Quadratec and it failed in the bleeding process, I am chalking it up to a defective part as maybe I'm a sucked but I don't think they would sell junk. They were very good about it they refunded my shipping and sent me another next day air, now weather that one is junk or not I will be posting.
BTW I would rather have a part with no warranty that lasted then one with one that didn't.
mudphish is offline
post #5 of 18 Old 12-15-2011, 10:25 AM
mighty4banger
I have a better situation for you.
I have a bell housing for the 2.5L external slave.
You could convert it to external while you are at it.
PM me if you are interested.
95 YJ 2.5L 5 speed, 4.88's, Aussie Locker D30, 35" Mud Rovers, Herculined tub, TKH rear bumper, Ford 8.8, JB Conv. SYE, Sylvania Silver Stars, T-MAX 9K winch, MORE 1" body lift, Turbo City oil pan skid, Rubicon Express 4" lift...
2012 KK Black all stock.
mighty4banger is offline
post #6 of 18 Old 12-15-2011, 10:42 AM Thread Starter
Xpress
Not too big of a deal for me to replace the slave cyl again. I know how that tranny comes off and could have it done in a few hours, by myself at that.
We'll keep in touch...
Xpress is offline
post #7 of 18 Old 12-15-2011, 04:29 PM Thread Starter
Xpress
Bump. Any opinions on the unit from Quadratec?
Xpress is offline
post #8 of 18 Old 12-15-2011, 05:30 PM
oldtime_ironman
Here's an opinion. Dunno if you can use the info. Back when the master went on my 87 cherokee, I found out that you could get either the aluminum/plastic cylinder, or the OEM style cast-iron one. The cast-iron one had a lifetime warranty against anything. The NAPA guy said the other ones had a reputation for warping and wearing out. So I paid the $100 for it. But I wonder if those would fit the wrangler. I never had to think about the clutch again after that. I got the cast-iron master, with the stock OEM internal slave and a borg-warner lifetime clutch kit. Total was about $290 and a weekend wrenching.
oldtime_ironman is offline
post #9 of 18 Old 12-15-2011, 05:42 PM Thread Starter
Xpress
The problem I am having is that this is my DD and I need to get to and from work whenever I am called in (I work weekends and am on call during the week). I don't have a ton of money to be spending on parts and i don't have a lot of time to do it. That's why I'd prefer to not buy the dealer part, its out of my budget range.
It's not that i want to go the cheap route as much as the inexpensive route.
Xpress is offline
post #10 of 18 Old 12-15-2011, 05:59 PM
mighty4banger
Wow the whole external assembly (master, line & slave) is only $30 more than the internal slave:
http://www.quadratec.com/products/52010_010.htm
You might even do better price wise from a local parts shop...
Check your PM's
post #11 of 18 Old 12-15-2011, 06:02 PM
mudphish
The Quadratec unit is from Crown Automotive they sell quality products. I will be installing my replacement unit tomorrow and will post if I have any issues.
mudphish is offline
post #12 of 18 Old 12-15-2011, 06:11 PM
oldtime_ironman
Well, I would trust the NAPA part just as good as the dealer part, especially if you get their "gold" top-of-the-line stuff. Seeing how yer stuck for time and its your DD (same as me) then I would just get the NAPA slave and be done with it. NAPA has never gave me bad stuff, everyone else has.
post #13 of 18 Old 12-15-2011, 07:04 PM Thread Starter
Xpress
I'm still weighing my options at this point... Have to see what the budget will allow.
Xpress is offline
post #14 of 18 Old 12-15-2011, 07:25 PM
oldtime_ironman
Just in case you need to know, I found out yrs ago that you can buy a rebuild kit for the master cyl. Basically just a few o-rings and a spring. It was like $20 at NAPA if I remember.
post #15 of 18 Old 12-16-2011, 01:18 PM
mudphish
Installed the new unit from Quadratec no issues the problem with the new unit that failed was one of the shipping straps did not let go when being bled this forced the bearing to canter and blow the seal.
mudphish is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 09:07 AM
Need new clutch slave/master cylinder: Quadratec or clutch city online? Links inside myoung YJ Wrangler Technical Forum 3 08-23-2010 05:49 PM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
