Clutch Going? - JeepForum.com
post #1 of 3 Old 06-21-2010, 08:24 PM Thread Starter
cubewhiz
Clutch Going?
How can I tell if my clutch is going? Also, how long from the time it "starts" to go do I have before it just won't work?
It's been a while since I've burned a clutch (never on the Jeep yet), so I don't really remember what it feels like, but it seems to me like I'm having a little trouble accelerating.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #2 of 3 Old 06-21-2010, 08:27 PM
USAFRecon
Does it rev a little more after you have takin your foot off the clutch, like actin like you still have your foot on the clutch pedal a bit? If so that is one sign.
USAFRecon is offline
post #3 of 3 Old 06-21-2010, 08:34 PM
monkeyhouse
first off, I don't think there is a real accurate way to answer your question. You would maybe get better response with more info as to what your problem is. You would have to determine if the problem is hydraulics or mechanical(physical clutch). Either way, once it starts to go, it typically will degrade quickly.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 09:07 AM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 08:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
