Clutch differences on model years - JeepForum.com
post #1 of 5 Old 04-08-2012, 05:07 AM Thread Starter
ashnken
I picked up a 95 YJ with no motor in but the guy had went to a salvage yard and got a 4.0 the clutch and pilot bearing are shot. I looked online and 94-95 clutches are listed seperatly. Is there any way to tell what year I have it has the sticker on the vale cover that says date code. I cant post any pics yet. THanks for any help.
ashnken is offline
post #2 of 5 Old 04-08-2012, 07:51 AM
wendell
1987 YJ Wrangler
I put an 87 clutch on a 91 AX-15 tranny without issue. Call Quadratech at 1-(800) 745-5337, there the jeep experts, they can help.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #3 of 5 Old 04-08-2012, 10:58 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
The LuK brand replacement clutch kit application chart shows part #05-065 for '94-'95 model 4.0L Wranglers.
They are identical.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 5 Old 04-08-2012, 11:54 AM
SnowdogMarc
I know the Internal and External slave master cylinders are different as is the mounting bolt pattern between the early YJ's and the second gen 90's YJ's. I had a 94 external slave housing and had to do a few mods to make the 94 master fit my 88. Bolt pattern as well as the push rod to clutch pedal mounting bolt hole are different.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #5 of 5 Old 04-08-2012, 03:02 PM Thread Starter
ashnken
I think the motor i got is a 96 by looking at the sticker on the valve cover. Thats what I was trying to figure out. Thanks!
ashnken is offline
Differences between the TJ model years Cannonball003 TJ Wrangler Technical Forum 5 03-27-2010 06:26 AM
Differences between the years gargyle TJ Wrangler Technical Forum 4 06-14-2008 06:47 PM
Differences in top years keithert TJ Wrangler Technical Forum 3 09-07-2006 10:53 AM
2.5 differences between years? chim YJ Wrangler Technical Forum 0 05-07-2006 06:27 AM
YJ model differences ryan_eyres YJ Wrangler Technical Forum 7 07-14-2002 10:49 PM
