Clutch changes - JeepForum.com
post #1 of 2 Old 01-01-2012, 05:55 PM Thread Starter
Dfrugia
Clutch changes
I just had a new clutch and flywheel installed. Works great other than sometimes the engaging/disengaging changes. I'll be at a light with it in first gear, clutch all the way down and it is trying to go forward....nothing is blocking the clutch on the floorboard. I can not make it duplicate the issue. Please help.
Dfrugia is offline
post #2 of 2 Old 01-01-2012, 05:59 PM
Mark05059
bleed your clutch hydraulics
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 09:07 AM
Need new clutch slave/master cylinder: Quadratec or clutch city online? Links inside myoung YJ Wrangler Technical Forum 3 08-23-2010 05:49 PM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 08:55 PM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
