clutch bleeding - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > clutch bleeding
Component speaker deal for your dash - NalinMFGJK Vent Covers - NalinMFGTJ 5.25" Speaker Adapters - NalinMFG
Unread 08-10-2014, 11:42 AM   #1
kjg26
clutch bleeding
I just converted to an external clutch slave cylinder with all new associated parts. On the test ride the clutch pedal feels very low, it still works. But very low still works, just engages very low. I'm going to try and bench bleed the system. But u can't find the bleed screw.
This is all that is on the slave.
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline   Reply With Quote
Unread 08-10-2014, 11:43 AM   #2
kjg26
Is this the bleed screw? And if it is, how the heck does it work?
Unread 08-12-2014, 07:08 AM   #3
kjg26
Well I went ahead and bleed the system as if that was not a bleed screw. I set up the master on my bench and hand pumped the slave until the bubbles stopped. Then blocked the piston of the slave with a steering wheel puller and pushed the master piston in. Had less than 1/8 travel. Good to go.
Unread 08-26-2014, 07:54 PM   #4
jeepchic95
i need to bleed mone as well...and i have the same slave. any updates on how to do it while still on the jeepster?
jeepchic95 is offline   Reply With Quote
Unread 08-26-2014, 08:58 PM   #5
kjg26
Watch "Bleeding External Clutch Hydraulic Release System…" on YouTube
Bleeding External Clutch Hydraulic Release System…:
YouTube (Short URL)
?start=" frameborder="0" allowfullscreen>
I did the part where he pumped the slave cylinder. It can be done on the jeep. Have someone watch the master cylinder as you're pumping. Worked well. Driving beautifully now.
Unread Yesterday, 05:49 AM   #6
Gage56
Gage56's Avatar
https://www.youtube.com/watch?v=8pZH...ature=youtu.be
1992 YJ
2004 Bmw 330XI
White Jeep Club #302
My Resto/Build Thread
http://www.jeepforum.com/forum/f12/my-official-build-thread-1992-yj-emma-1494420/
Another YJ Resto
http://www.jeepforum.com/forum/f22/p...81/?highlight=
Sun Visor Fix How To
http://www.jeepforum.com/forum/f12/s...x-how-1607617/
Originally Posted by Tom95YJ View Post
This is a prime example why people should be give a IQ test before they are allowed to Vote or Breed.
Gage56 is online now   Reply With Quote
