Clutch acting wierd? - JeepForum.com
post #1 of 5 Old 04-09-2013, 08:57 PM Thread Starter
rtillery34
1987 YJ Wrangler
Just this past weekend I replaced the clutch, new pressure plate, disc, pilot and throw-out bearing. Now the issue is when I'm starting off in either reverse or first and as I release the clutch and accelerate I get some shaking in the rear end. Could it be I need to bleed the clutch again or could it be the driveline? Not sure need some help please!!!
rtillery34 is offline
post #2 of 5 Old 04-10-2013, 06:36 AM Thread Starter
rtillery34
1987 YJ Wrangler
Any help?
post #3 of 5 Old 04-10-2013, 06:46 AM
Louie4
Check your transmission mount and the stabilizer bushings. I found that my stabilizer bushing had vanished and my entire tranny/t-case would shake in 1st. You may also want to check the engine mounts.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 5 Old 04-10-2013, 05:19 PM Thread Starter
rtillery34
1987 YJ Wrangler
When tightening down the tranny mount do I tighten the torx arm first then the mount bolts? Any suggestions would be greatful! Thanks!
post #5 of 5 Old 04-10-2013, 06:14 PM
Louie4
I recently changed out my bushings on the torque arm. II put the stabilizer stud in with the bushings and tighten them down. Then I put the cross member on tighten the bolts on the mount. Then I tighten the torque arm.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
