clutch - JeepForum.com
post #1 of 2 Old 10-27-2001, 11:21 AM Thread Starter
rev
clutch
does anyone know if its possible for air to get into the hydraulic clutch with no visable leaks?
rev is offline
post #2 of 2 Old 10-28-2001, 01:03 AM
Ruftags
If the rubber seal under the resivoir is crimped or damaged it could be sucking in air everytime you press the peddle.
95 YJ 2.5L AX5 30in. rubber.
So many upgrades/So little cash!!
Ruftags is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 09:07 AM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 08:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
