CLUTCH - JeepForum.com
post #1 of 2 Old 10-25-2001, 09:43 AM Thread Starter
LA93WRANGLER
CLUTCH
Hello, I am new to the forum. I was thinking about changing my 30 BFG AT's to 32 or 33's. I have a skyjacker 2 1/2" lift, and stock gears with manual tranny. Has anyone ever done this and if so did you have any clutch problems?
LA93WRANGLER is offline
post #2 of 2 Old 10-25-2001, 10:41 AM
powjunkie
With 2.5" inches, you'll have some rubbing with 33's. If you like to play on the rocks, I'd go with no more than 32's (31's would be better) with a 2.5". Anyway, if you do go with 33's, your clutch will go out a little sooner than normal. It's really not that bad, though. I ran 33's with 3.07 (stock) gears for 3 years before I finally did a gear swap. Expect about 70K miles out of your clutch assuming you have a 4.0L.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 09:07 AM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 08:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
