Quantcast clutch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > clutch
East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.Great deals on Rigid Lights. SR and E series
Old 01-19-2009, 10:02 AM   #1
ks90yj
clutch
Where is the best place to buy a clutch for my ax-15 that im about put into my yj? also cheep im on a tight budget
DINSTAAR
ks90yj is offline   Reply With Quote
Old 01-19-2009, 10:12 AM   #2
DanAepel
I just went with www.gripforce.com for an Exedy Clutch and new flywheel. Parts fit great and working like new. I shopped around a bit, seemed like the best deal. Good luck.
'90 YJ, 4.2 L, Nutter Bypass, DuraSpark Upgrade, MC2100, no more emissions junk, K&N air filter, AX15, 4" Leaf Lift, 33" Tires, 7" Flares
DanAepel is offline   Reply With Quote
Old 01-19-2009, 10:19 AM   #3
ks90yj
they dont have a jeep link. which clutch would it be?
DINSTAAR
Old 01-19-2009, 10:25 AM   #4
DanAepel
Try this link through Ebay and seach for Jeep.
http://stores.ebay.com/gripforce-clutches
Old 01-19-2009, 10:30 AM   #5
Futaba
i got mine at autozone only because of the lifetime warranty free clutchs for life! works fine for me.
Futaba is offline   Reply With Quote
Old 01-19-2009, 10:38 AM   #6
ks90yj
how much was that? Is it a good clutch?
DINSTAAR
Old 01-19-2009, 10:42 AM   #7
ks90yj
if it says 87-92 wrangler/ cherokee is that a good on for my 90? and is $144 good for a luk?
DINSTAAR
Old 01-19-2009, 10:45 AM   #8
Futaba
i cant remember exactly how much but it was more then $100 but less then $150 and that includes the slave and aliment tool.
to be honest i dont know if its a good clutch or not i just own a jeep and a few wrenches. i replaced mine about 6 months ago and been wheeling the piss out of it and it still works fine. anyways if it does crap out just bring it back and get a new one for free thats why i like autozone.
Old 01-19-2009, 11:12 AM   #9
Fenix85182
On that site, it actually says "87-92 JEEP WRANGLER CHEROKEE 2.5L LUK CLUTCH+SLAVE KIT "
That '2.5' denotes the 2.5L 4-cylinder engine. Make sure it's your engine and you're golden.
Edit: I just realized you said AX-15 in your first post, which was the tranny specifically for the 4.2 and 4.0 6-cylinder engines, so no, that is not the clutch for you.
1989 Jeep Wrangler Laredo - 4.0L, 32" BFG M/Ts, 3" Lift
1997 Acura 2.2CL
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline   Reply With Quote
Old 01-19-2009, 11:23 AM   #10
newtjrjrjr
X2 its a decent clutch for the price. Cant beat the lifetime warrenty
newtjrjrjr is offline   Reply With Quote
Old 01-19-2009, 11:47 AM   #11
ks90yj
Hey I've got another question for you. I just bought my jeep a month ago and well im retarded.the people who had it before me replaced the engine I dont remeber if the just redid it or actually replaced it. I have looked around and I dont see anything that will identify the type of engine or any thing. Is there a way to tell what kind of engine I have? I have counted all the plugs on the dis. cap and there are 7 of them does this mean I have a 6 cyl? Basically I really just wanted the jeep and it was cheep so I bought it.
DINSTAAR
Old 01-19-2009, 03:02 PM   #12
Bigboyky
Man you have lots reading to do. Start with the FAQ section on here. Next get a Haynes manual for your jeep. Read up and have fun with your jeep
Bigboyky is offline   Reply With Quote
Old 01-19-2009, 03:08 PM   #13
Allen52105
check CarolinaClutch.com they gave me a great deal even with shipping here is a Heavy duty one for ya
http://carolinaclutch.com/ShowItem/105138%20Jeep%20Luk%20Pro%20Gold%20Heavy%20Duty%20 Clutch%20Kit.aspx
jason
Allen52105 is offline   Reply With Quote
Old 01-20-2009, 12:00 AM   #14
Fenix85182
That does mean you have a 6-cylinder. Next, you want to determine the type of engine. Each block actually has a casting number that you could match up and determine the exact year and specifications of the engine in the Jeep. However, there are easier ways.
Know the difference between a carburetor and fuel injection? If you have a carburetor, it's more than likely the 4.2L inline 6. If you have fuel injectors it's a 4.0L inline 6 (which is better for efficiency and power).
Next is transmission. If you have the 4.0L fuel injected motor, it is ery likely the Aisin AX-15 tranny. If you have the 4.2L carburated motor, then you may have one of two of the following trannies. There is a clear difference between what the two possibilities of the tranny you have are: the Aisin AX-15 or Peugot BA-10/5. I'm sure the trannies are marked if you get close enough, as the model is casted into the aluminum casings, I just cannot remember what it says and where exactly they are located. Your best bet is to look up the pics on google and look for similar matching characteristics. Chances are that if it is still running well, it's the Aixin AX-15. Chrysler ditched the Peugot BA-10/5 for a reason.
1997 Acura 2.2CL
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
