Clunky sound under jeep - JeepForum.com
post #1 of 12 Old 09-25-2017, 06:38 PM Thread Starter
jeepercreeper92
My 92 has a cluck sometimes when I pull off and now while I'm driving when I let off the gas.it's getting worse and I need to know what it is. Any help would be appreciated.thx
jeepercreeper92 is offline
post #2 of 12 Old 09-25-2017, 07:07 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Please fill in your JF vehicle profile so we can better assist you in your endeavor to solve the mystery clunk.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #3 of 12 Old 09-25-2017, 07:54 PM
shaggyjim
shaggyjim's Avatar
Check you engine and tranny mounts. Then your u joints.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #4 of 12 Old 09-26-2017, 08:51 AM Thread Starter
jeepercreeper92
It's a 92 with a straight 6 and a straight drive. How do I check the mounts?
post #5 of 12 Old 09-26-2017, 10:14 AM
mike134
For the engine, give it a quick pump of the gas and then let it go quickly. Does the engine move significantly?
For the transmission, the best way is to just change it for about $12 if you haven't done so in a while. While you're down there... change your transmisison, transfer case, and diff fluids, maybe even add in a few more maintenance items and make a day of it.
Also, check your transmission and transfer case bolts to make sure they are tight. Sometimes these work loose after years.
mike134 is offline
post #6 of 12 Old 09-28-2017, 04:25 AM Thread Starter
jeepercreeper92
Thx, I'll try that. Now the sound has stopped when I let of the gas. It only does it every now and then.
post #7 of 12 Old 10-02-2017, 04:30 AM Thread Starter
jeepercreeper92
Update.... The sound has gotten worse.went to AutoZone and guy heard the sound and said it sounds like it's coming from the transmission.there is a local shop here that deals in nothing but jeeps.im going by there my next day off
post #8 of 12 Old 10-02-2017, 06:35 AM
TSEJEEPERS
If you still have your trac bars check them and make sure they have not come loose.
Especially the rear one.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 12 Old 10-02-2017, 06:41 AM
aaonms
aaonms's Avatar
2017 JK Wrangler
Sent using Tapatalk
aaonms is offline
post #10 of 12 Old 10-02-2017, 07:54 AM Thread Starter
jeepercreeper92
Rear trac bar has been gone for years
post #11 of 12 Old 10-02-2017, 08:16 PM
mike134
That happens? I thought they just rust seized into position and made the ride unbearable and more dangerous.
mike134 is offline
post #12 of 12 Old 10-07-2017, 06:56 AM Thread Starter
jeepercreeper92
I've been talking to a shop near me that does Jeep builds and they seem to think it's my transmission.i did check the fluid in the transfer case.it was low,so i filled it up.still making the sound.i can't get the fill plug out of transmission.so I'm gonna pop of the boot from my shifter and add some fluid there to see if it helps
