clunking in rear over bumps, getting more frequent - Page 3 - JeepForum.com
post #31 of 35 Old 02-12-2011, 12:09 PM
cojab
Hey dirn, I was checking mine out yesterday also. The bushings on my shocks are definitly worn out and I had bushings to replace one of them. I need to order some more for the others. One other thing that I noticed while under it though might be where Im getting a lot of noise. The slip yoke going into the transfer case on mine is loose and I can simulate the noise by shaking it. Im also getting a leak from the seal. I get my clunking noise when accelerating or going through turns also which I think could be explained by the axle wrapping a bit under those conditions. Not sure if this helps you but you might check it. Looks like a SYE kit and CV driveshaft is next on my list of mods. This was never done on mine when the PO installed the first lift.
cojab is offline
post #32 of 35 Old 02-12-2011, 12:15 PM
navis
I was having this same problem. Turns out the ubolts loosened off a lot after my axle swap. It would be especially prominent when accelerating and turning at the same time. I would make sure you have the right pinion angle as well, because of that itDESTROYED my CV
navis is offline
post #33 of 35 Old 02-16-2011, 06:16 PM Thread Starter
dirn
I'll check the sy tomorrow. I never thought to check that, thanks.
dirn is offline
post #34 of 35 Old 02-16-2011, 06:18 PM Thread Starter
dirn
I had my ubolts loosen on me too, but caught it a while ago (summer time).
dirn is offline
post #35 of 35 Old 10-19-2013, 09:03 AM
BigDustyman
Had same problem turned out to be bad shocks
BigDustyman is offline
bumps , clunking , clunking noise , YJ
clunking in rear when going over speed bumps plumber1 YJ Wrangler Technical Forum 16 09-22-2008 11:28 PM
squeak in rear end when going over bumps gerrynjr TJ Wrangler Technical Forum 9 08-27-2006 02:48 PM
Clunking from front pass side going over bumps...driving me nuts!! Help please. RipcordAFF TJ Wrangler Technical Forum 10 10-17-2005 11:36 AM
clunking noise below feet while turning and bumps elkriverjeep TJ Wrangler Technical Forum 3 06-27-2002 12:21 PM
clunking noise below feet while turning and bumps elkriverjeep TJ Wrangler Technical Forum 1 05-26-2002 12:29 PM
