clunking in rear over bumps, getting more frequent - Page 2 - JeepForum.com
post #16 of 35 Old 02-04-2011, 08:50 AM
ZeroGravity
Just back it up to the computer, we can take it from here.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #17 of 35 Old 02-05-2011, 04:49 PM Thread Starter
dirn
Ok..... done... what now? :-)
dirn is offline
post #18 of 35 Old 02-09-2011, 09:23 PM
K4KAS
Did you figure out what it was?
K4KAS is offline
post #19 of 35 Old 02-10-2011, 07:29 AM Thread Starter
dirn
No not yet... I believe its the shock or the bushing tho.
I haven't crawled under it yet...
dirn is offline
post #20 of 35 Old 02-10-2011, 08:11 AM
jbolty
jbolty's Avatar
Just thinking out loud here but if you have a strange clunking noise under your vehicles would it not make sense to look underneath before doing anything else?
jbolty is offline
post #21 of 35 Old 02-10-2011, 12:24 PM
Mark05059
its easier to go to the computer and type to people who cant see/touch/hear the jeep and have them guess
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #22 of 35 Old 02-10-2011, 01:18 PM
jmmorgan82
2009 JK Wrangler
I have the same noise. I know it is worse if I have any gear in the back or anyone riding in the Jeep with me. Seems to be coming from the rear passenger area. Whenever I take off the hardtop and/or take out the back seat the noise disappears. I've chalked it up to something with the suspension and will just live with it until I put a lift on.
jmmorgan82 is offline
post #23 of 35 Old 02-11-2011, 07:10 AM Thread Starter
dirn
Yes, that sounds like my problem almost to a t. I do have a lift is the only exception.
dirn is offline
post #24 of 35 Old 02-11-2011, 07:16 AM Thread Starter
dirn
Jbolty- let me be more clear. Ive looked underneath, I just haven't put it on a lift yet. I've checked bolts, looked for broken mounts, and other oddities... nothing
That was my bad, I shouldn't have said it the way I said it.
dirn is offline
post #25 of 35 Old 02-11-2011, 07:38 AM Thread Starter
dirn
mark -
I asked the question, not because I didn't have my own ideas or wanted to have everyone else try to diagnose the problem. I asked because I wanted to see if anyone else had the same problem and to get some other ideas on things maybe I didnt think of.
dirn is offline
post #26 of 35 Old 02-11-2011, 07:58 AM Thread Starter
dirn
How long have you had the noise? Long time, has it gotten worse?
dirn is offline
post #27 of 35 Old 02-11-2011, 12:13 PM
jmmorgan82
2009 JK Wrangler
I'd say it's been there for about 2 months. It seems to be worse when it's cold out. I haven't gotten under there to check anything yet, but I'm replacing my torque arm and tranny mount next weekend so I'll try to figure it out then.
post #28 of 35 Old 02-11-2011, 03:08 PM
SpideYJeep
Check the rubber muffler hangers?
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #29 of 35 Old 02-11-2011, 10:37 PM Thread Starter
dirn
So I found the problem... the shocks were loose.
I thought maybe a bushing, but the shock was literally loose.
So I checked the rest and they were all loose to some degree. I was a little surprised, its the first time I've seen all 4 loosen up like that. All at the top too. I'm going to tighten them up tomorrow, hopefully that does the trick.
dirn is offline
post #30 of 35 Old 02-12-2011, 11:09 AM Thread Starter
dirn
So i jumped the gun a little, it is bushings in the rear. Fronts snugged up a little but needs bushings too
dirn is offline
bumps , clunking , clunking noise , YJ
clunking in rear when going over speed bumps plumber1 YJ Wrangler Technical Forum 16 09-23-2008 12:28 AM
squeak in rear end when going over bumps gerrynjr TJ Wrangler Technical Forum 9 08-27-2006 03:48 PM
Clunking from front pass side going over bumps...driving me nuts!! Help please. RipcordAFF TJ Wrangler Technical Forum 10 10-17-2005 12:36 PM
clunking noise below feet while turning and bumps elkriverjeep TJ Wrangler Technical Forum 3 06-27-2002 01:21 PM
clunking noise below feet while turning and bumps elkriverjeep TJ Wrangler Technical Forum 1 05-26-2002 01:29 PM
