clunking in rear over bumps, getting more frequent - JeepForum.com
post #1 of 35 Old 02-02-2011, 05:53 PM Thread Starter
dirn
I'm getting a clunking sound in the rear end, sounds like its on the passengar side. I've noticed that it is getting worse.
Now some back ground info that might be useful.
4" suspension lift- 2yrs old
no rear track bar...
I think its a shock but was wondering if the suspension could be working loose? Any other suggestions would be greatly apprecieated!
Dan
dirn is offline
post #2 of 35 Old 02-02-2011, 06:09 PM
fishsniper
In your driveway, try just real slowly and easily rolling forward. If it seems to kinda hang up and not roll smoothly at one point, it could simply be an equalizer in your rear drum. Mine was making a sort of thumping/clunking noise from the rear drivers side and it turned out to just be that equalizer. Got it fixed for free. Hope this helps and thats all it is!! Good luck!
93 YJ, 2" BL w/ 2.5" springs, rear track bar removed, 31x10.50s DuraTracs, 4.0, 5 speed
On a quiet night you can hear the sounds of a HUMMER rusting in the mud, and the man crying when a JEEP is pulling him out
fishsniper is offline
post #3 of 35 Old 02-02-2011, 06:11 PM
Findlay_Jeepin
I would check the torque on the spring hanger bolts. Also check the shock mounts to see if they have come loose.
I had a similar issue with a old truck and found it was actually a rusted out body mount causing the noise.
AC
Findlay_Jeepin is offline
post #4 of 35 Old 02-02-2011, 06:30 PM
dillonjm
2013 WK
I'd just go shake the shock and see if it clunks. If not I'd look at the springs next, then start looking at more obscure items.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #5 of 35 Old 02-02-2011, 06:42 PM
jbolty
jbolty's Avatar
when is it happening?
rolling, speeding up, slowing down, turning?
jbolty is offline
post #6 of 35 Old 02-03-2011, 05:37 AM Thread Starter
dirn
I will check those all out.. thanks
The clunking happens all the time.
dirn is offline
post #7 of 35 Old 02-03-2011, 05:40 AM
moody
this may sound crazy but I had the same clunk and was searching everywhere for it and found it was my seat had came unlatched and everytime I hit a bump he would bounce a little...
moody is offline
post #8 of 35 Old 02-03-2011, 06:36 AM
grandboost98
i found that mine was my exhaust hanging too low and hitting stuff
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is online now
post #9 of 35 Old 02-03-2011, 09:11 AM
GaJeepy
Get in there and check your brakes. When I bought my jeep it was making the same sound on the passenger side. When I pulled the hub off, springs and other fun parts from the brake system were laying all over the place.
livin' out the music de punk
MUD FLIES WHEN YOU'RE HAVING FUN. ~Red Jeep Club #574
GaJeepy is offline
post #10 of 35 Old 02-03-2011, 11:21 AM
cojab
Im having the same clunking noise (I think) as you. I was under the Jeep looking for the cause and everything looked good on mine other than the shock bushings. All kinds of slop in them and I could move the shocks about 3/4" by hand. Ive got some left over poly shock bushings in the shop so as soon as it warms up a bit around here Im going to replace those and see if it helps mine. I'll let you know if you dont have yours done first.
cojab is offline
post #11 of 35 Old 02-03-2011, 04:32 PM
baritone_mike
Mine makes a clunking noise when I go over speed bumps, it sounds like it is coming from the rear also. It did it when I got it stock and then I lifted it and changed all four breaks, and it still does it. I am going to check my seat and see if that helps.
baritone_mike is offline
post #12 of 35 Old 02-03-2011, 04:41 PM
SpideYJeep
Check your exhaust and your rear track bar (if'n u still gots it)
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #13 of 35 Old 02-03-2011, 05:00 PM
jbolty
jbolty's Avatar
Lots of things could be loose. Get under there and first look for fresh bang marks. Next grab everything and see if it moves; the most common would be shocks, ubolts or transmission mount.
Get someone to drive slown and lay in the back with your head out the tailgate and look and listen.
Broken spider gears will make a clunck noise as well, which I why I asked earlier about when it was happening. A common symptom for a broken spider would be if the noise happens when accelerating out of a turn; but it is not always like that.
jbolty is offline
post #14 of 35 Old 02-03-2011, 05:52 PM
baritone_mike
I would guess mine is comeing from my tire carrier. I have a bumper with a swing out carrier and the carrier moves up and down on the end that swings. It is not that big of a deal for me but if you have a aftermarket bumper I would check to see if any thing on it moves.
post #15 of 35 Old 02-04-2011, 05:35 AM Thread Starter
dirn
No rear track
I have a feeling its suspension related. I did have to re-torque the ubolts back in the summer, they got real loose. I'm hoping its a shock or a loose nut somewhere.. gonna check a little today
Oh yeah, no tire carrier either.
dirn is offline
bumps , clunking , clunking noise , YJ
clunking in rear when going over speed bumps plumber1 YJ Wrangler Technical Forum 16 09-22-2008 11:28 PM
squeak in rear end when going over bumps gerrynjr TJ Wrangler Technical Forum 9 08-27-2006 02:48 PM
Clunking from front pass side going over bumps...driving me nuts!! Help please. RipcordAFF TJ Wrangler Technical Forum 10 10-17-2005 11:36 AM
clunking noise below feet while turning and bumps elkriverjeep TJ Wrangler Technical Forum 3 06-27-2002 12:21 PM
clunking noise below feet while turning and bumps elkriverjeep TJ Wrangler Technical Forum 1 05-26-2002 12:29 PM
