Quantcast Clunking in rear, dana 35 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Clunking in rear, dana 35
Old 02-04-2007, 01:49 PM   #1
ppandr
Just replaced rear diff assembly because the other was shot. Replaced with used unit. Checked it out thoroughly before installing and everything was tight and the oil was clean. Everything being bolted in drove it in parking lot and getting a severe clunking. Can't seem to figure what triggering it. Does not happen often, maybe three/four times in 5 minutes. Help.....
ppandr is offline   Reply With Quote
Old 02-04-2007, 02:42 PM   #2
Why J?
Could be loose u bolts, mine was doing the same and with the 35's i figured it was heading out. One afternoon I crawled under there with a deep 3/4 socket and a 3' breaker bar and re torqued all of the u bolts. No more cluck.
New Project "Pissed Wife"
http://www.jeepforum.com/forum/f12/project-pissed-wife-747535/
Why J? is offline   Reply With Quote
Old 02-04-2007, 09:38 PM   #3
notmyj
Part of the Three Percent
notmyj's Avatar
Check the u bolts and u joints. Did you forget to install any shims between the springs and spring pads if you have a lift.
www.pghoffroad.com
My SOA Build
Recovery Gear Basics
My BUDGET York OBA Install
Budget Welding Cart
Carling Contura Switch Panel
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone installs a S35 kit or otherwise "upgrades" a D35, an angel looses its wings."
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x8, 35's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline   Reply With Quote
Old 02-04-2007, 09:57 PM   #4
t_rexx70
"If it has tracks, tires or tits, it will give you a headache"
Man I was in the Army and had to deal with tracks. You are 100% correct on that statement...all of them require the use of advil!!!!
[COLOR="Blue"][FONT="Arial Black"][SIZE="4"]88YJ 4.2l, weber 32/36, nuttered, 4" super lift, TFI, stock 30 and 35 pos axles alloy 4.10's, lockrights, posilocked, 33 X 12.50 Mudbrutes[/SIZE][/FONT][/COLOR]
t_rexx70 is offline   Reply With Quote
Old 02-04-2007, 10:22 PM   #5
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
http://www.differentials.com/diagnose.html
Joe Dillard is offline   Reply With Quote
Old 02-04-2007, 10:45 PM   #6
Monk89 94 I4
Originally Posted by Joe Dillard
thanks joe, id assume more than one member can use that information!
94 was a great year for the yj, 2006 was a great year when i put the sport cage in it...
Monk89 94 I4 is offline   Reply With Quote
Old 02-04-2007, 10:53 PM   #7
notmyj
notmyj's Avatar
Ha, your the first person who commented on that line...
Heavy equipment mechanic for a while... When a Cat D9N throws a track, and its 15* out side, and the only excavator around has no windows, you quickly learn to hate tracks.
Tracks are great until a machine throws one. lol.
www.pghoffroad.com
My SOA Build
Budget Welding Cart
Glock Forum
