Quantcast Clunking/popping in front end - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Clunking/popping in front end
Old 04-23-2006, 11:08 AM   #1
BudmanV6
I have a clunking/popping noise in my front end. Usually surfaces when making slow speed turns of 15mph or less. Especially does it when in parking lots. It sounds like its the power steering pump. Does this sound reasonable? I've heard of whinny pumps before, but not ones that popped or clunked.
1992 Wrangler Sahara, 4.0L, 5spd, RE 4.5 XD lift, Fox remote reservoir shox, 33x12.5-15 BFGoodrich All-Terrains, 15x8 black rock crawlers, JK rubicon pneumatic swaybar, JKS quick disconnect track bar, Teraflex HD SYE, Tom Woods driveshaft, Ford 8.8 w/ 4.10 gears and arb locker, D30 w/ 4.11 gears and arb locker, York 210R OBA w/ Kilby mount, Dynomax Ultra Flow SS muffler, Alterstart 165A alternator, TJ flares, and Poison Spyder rocker knockers.
BudmanV6 is offline   Reply With Quote
Old 04-23-2006, 11:09 AM   #2
TellyDSP
Poland and PPV!!!!
sounds like your 4WD is engaged.
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline   Reply With Quote
Old 04-23-2006, 12:05 PM   #3
Mark_ZZ3
Check your u-joints in your axle shafts. If worn badly, you will get all sorts of clunks and pops.
Mark.
Mark_ZZ3 is offline   Reply With Quote
Old 04-23-2006, 12:12 PM   #4
Tshark299
1987 YJ Wrangler
Mine makes the same noises. In my case it's my tie rod rotating when turning the steering wheel... it doesn't do it every time though. With the lift, the drag link is now at an angle, which sometimes makes the tie-rod/drag-link assembly rotate. I had someone rotate the steering wheel back and forth while I looked under the front end. It did this with my old worn out parts and still does with the new tie rod and drag link i installed last year.
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parting the rest out
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline   Reply With Quote
Old 04-23-2006, 10:17 PM   #5
BudmanV6
U-joints are fairly new. I installed a jks quick disconnect track bar recently, but it sounds like its coming from withing the power steering box.
Old 04-24-2006, 01:33 AM   #6
Bob_R
newbie
Unless your steering box is lose it should not make a clunking sound, just a wining nose which is not uncommon either. You could add a stiffner to the steering box and see if that helps. I have a super pump and it still makes noise but does not clunk. As mentioned my tie rod seems to be the culprit making my popping noise. Does it happen at a particular turn (to the left or to the right) or acceleration?
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL TREAD LIGHTLY
Bob_R is offline   Reply With Quote
Glock Forum
