Clunking noise from left front - JeepForum.com
post #1 of 12 Old 12-19-2012, 02:51 PM Thread Starter
flcracker
Just noticed this the other day and thought it might have not been something on the Jeep but on the ground, did it again last night pulling into the driveway. When I turn sharp left over a small bump, it makes an audible "thunk" and small bump up through the wheel. I thought it was coming from left front but son thought it was right front.
Ideas??
flcracker is offline
post #2 of 12 Old 12-19-2012, 03:24 PM
Old4X
1990 CJ7
Are your track bars and sway bar still installed?
Checked for loose shock mounts?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 12 Old 12-19-2012, 03:56 PM
jonmaclean19
could be the sway bar bushings. you can usually see seperation from the bushing to the bar
jonmaclean19 is offline
post #4 of 12 Old 12-21-2012, 08:32 AM
bob6987
motor mounts?
1991 YJ, 4.0, 6" lift, 40" tires, full cage, dana44/ford 9, detroit locker, 5.38 gear
2012 JKU
bob6987 is offline
post #5 of 12 Old 12-21-2012, 09:18 AM Thread Starter
flcracker
Track bars were the first thing we did to it... Sway bars are still there but with the lift and stock links that could be the problem, jsut odd that it just now showed up
post #6 of 12 Old 12-21-2012, 06:11 PM
Mywrangler94
with a lift and the stock links, you now change the angle with which they sit in the sway bar, and on the axle. So they just may be worn out. As far as the bushings, same same. Take off the links, see if the noise goes away. It will be mushy on turns, and lean a bit more. Keep that in mind. Try it and let us know.
Mywrangler94 is offline
post #7 of 12 Old 12-21-2012, 07:11 PM Thread Starter
flcracker
Son is going away to KY for Christmas to see his mom... I'll try unhooking it and see what happens....
post #8 of 12 Old 12-21-2012, 09:05 PM
jdubsjeep
Clunks from the front right usually are going to be your axle ujoint on the passenger side. Look at the axle housing behind the passenger front wheel, where the 2 axle shafts are exposed and you will see a ujoint. Check it carefully, I bet it is shot. Not a terribly difficult job to fix. Check the write up to do the job.
jdubsjeep is offline
post #9 of 12 Old 12-22-2012, 04:38 PM Thread Starter
flcracker
That was the first thing I checked, both sides, and could get no play out of them using a long screwdriver through the joint and prying up and down.... didn't get silly with a crowbar or anything but it seemed to be pretty tight.
post #10 of 12 Old 12-23-2012, 08:55 PM
jdubsjeep
engage your 4wd and make a left turn. sometimes the pressure on the ujoint in 4wd will keep it from clicking. Is it a one time bump or a continuous clicking?
post #11 of 12 Old 12-23-2012, 10:15 PM Thread Starter
flcracker
just when I turn and have a small bump....
post #12 of 12 Old 01-04-2013, 11:32 PM
apougnet3701
I had the same problem for the longest time check your exhaust and see if any hangers are broken. Mine attaching to the transfer case mount was broken and causing the exhaust to hit the front driveshaft on graded turns
apougnet3701 is offline
