Clocking on the 231 transfer case - JeepForum.com
post #1 of 13 Old 06-18-2010, 06:34 PM Thread Starter
Bastidjeep
Is the difference on the transfer case or is it on the trans between the cherokee and the wrangler?
Bastidjeep is offline
post #2 of 13 Old 06-18-2010, 06:35 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
The transmission mounting holes are different on the cherokee. The transfer cases are the same.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #3 of 13 Old 06-18-2010, 06:39 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Ult is right, however the trans (AX-15) has room for both sets of drilled holes in the 6 interface bosses. I drilled out my AX-15 to allow the other clocking.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #4 of 13 Old 06-18-2010, 07:06 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
When using a non YJ AX tranny in a YJ, the NP231 transfer case will hit the skid plate because the T-case is "clocked" 10 degrees lower on the driver side, but you can redrill the location of the mounting holes at the rear of the transmission.
The transfer case clocking is determined by the mounting holes on the output of the transmission. Simply redrill the holes to raise the transfer case to the YJ height. In this pic, the holes on the right on each tab are the newly drilled holes that the YJ configuration requires to clear the skid plate.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 13 Old 06-18-2010, 07:35 PM
Area.3.Fiftyone
This should just be made a sticky already considering how many times it gets asked.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #6 of 13 Old 06-19-2010, 05:10 AM
JeeperDon
JeeperDon's Avatar
You are making the assumption that the existence of a perfect answer in a sticky/FAQ somehow reduces the occurrence of newbs asking anyway. What it does is give us a place to point them too, and maybe type a bit less.
Web Admin for
post #7 of 13 Old 06-19-2010, 06:07 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Max
Was this done by you??? Can you do a write up if so?????
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #8 of 13 Old 06-19-2010, 12:20 PM
Douglas S.
It's a fairly simple procedure. Just make a template, rotate the template, mark and drill.
Took me about 30 minutes.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #9 of 13 Old 06-19-2010, 03:01 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
No it wasn't, but I have a template for doing that procedure. Coincidentally I have an AX-15 on the bench right now. It's a true YJ model, but I can use my template to demonstrate & document the procedure.
Max
Mean Max is offline
post #10 of 13 Old 06-20-2010, 12:02 PM Thread Starter
Bastidjeep
Max
I hope to see this soon. Thanks in advance for a write up.
post #11 of 13 Old 10-23-2012, 01:59 PM
dukeryder
Max
So does this means that a NP 231 from an XJ, swapped into a YJ won't need any re-clocking?
dukeryder is offline
post #12 of 13 Old 10-23-2012, 02:58 PM
JeeperDon
JeeperDon's Avatar
Yes, fits in fine.
Web Admin for
post #13 of 13 Old 10-23-2012, 05:23 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Here is one technique for redrilling the output housing of a transmission to re-clock the transfer case. http://www.stu-offroad.com/engine/aw-4b/aw-4b-4.htm
As frequently as this gets asked, we really should have our own writeup though, I dont have an XJ tranny laying around to do this on or I'd do one up for the FAQ.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
Drivetrain swap. Transfer case ? Clocking kurt13r YJ Wrangler Technical Forum 13 08-03-2009 04:35 PM
transfer case clocking question! jaywiz1977 YJ Wrangler Technical Forum 1 06-16-2009 10:24 AM
dana 300 t-case clocking ring question cajun-jeep YJ Wrangler Technical Forum 1 05-04-2009 09:24 PM
Transfer case boot for 231c transfer case in jeep wrangler kniteman YJ Wrangler Technical Forum 2 03-16-2009 01:28 PM
clocking the T-case red87yj YJ Wrangler Technical Forum 1 11-06-2007 04:31 PM
