Clicking under the hood - JeepForum.com
post #1 of 9 Old 11-01-2013, 07:51 PM Thread Starter
33chief
1987 YJ Wrangler
I have an 87 YJ, 2.5 liter manual. The other day I got in it and it started right up. An hour later, I went to start it and all I got was clicking ( click, click, click) and it sounded like the engine wanted to turn over but, just couldn't.
My battery is almost new and so is my starter. I tried to jump start it but there was still the clicking....
I eventually pulled the negative cable from the battery and reconnected it a minute or two later. The engine cranked right over.
This morning the engine turned over no problems, clicking, etc.
Later this afternoon it was very slow to turn over . It eventually did.
Any ideas or has anyone experienced this before? And what was the outcome?
33chief is offline
post #2 of 9 Old 11-01-2013, 07:56 PM
crackedcornish
first thing I would do is build some better than OEM battery cables
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #3 of 9 Old 11-02-2013, 09:59 AM
dancytron
Bad battery cables. Probably corroded on the inside. Easiest way to replace them is to get marine terminals and regular lugged cables. Going up a size or two won't hurt.
dancytron is offline
post #4 of 9 Old 11-02-2013, 05:08 PM
willawolfe
Bad connection. Take terminals off hit with some sand paper try again. Should be an easy, hope you resolve your issue.
willawolfe is offline
post #5 of 9 Old 11-04-2013, 06:06 AM
vadslram
Agree
It's either bad cables, bad connections or both.
I run two ground straps on mine, One to the engine and one the goes from battery to body to frame. Since a lot of years jeeps have the starter solenoid mounted on the firewall and don't have a seperate ground wire, If you don't have a good solid ground to the body it will act up.
vadslram is offline
post #6 of 9 Old 11-04-2013, 06:12 AM Thread Starter
33chief
1987 YJ Wrangler
Thank you for the great advice! You were all correct in it being the wires and terminals.
I replaced both with marine grade products and it Started right up.
33chief is offline
post #7 of 9 Old 11-04-2013, 06:22 AM
responder
There you go, quick and straightforward. Glad your problem is solved
responder is offline
post #8 of 9 Old 11-04-2013, 06:27 AM
crackedcornish
good to hear you fixed the problem...what gauge wire did you end up going with?
post #9 of 9 Old 11-04-2013, 06:42 AM Thread Starter
33chief
1987 YJ Wrangler
I went with #2
33chief is offline
